Question about Kenmore Elite 45986 Front Load Washer
Front loader My washer is a front loader, does it also have one of those switches . If so Where?
  • 1 more comment
  • adaubon Jan 30, 2009
    I took it apart, nothing found
    Model # 41744102301
  • adaubon Jan 31, 2009
    I replaced the pump and it is back to normal, Thanks
  • Kenmore Master
  • 2,651 Answers
Wasnt aware its was frontloader, short of blockage of pump, it should drain, ifthe door wasnt locking, it wouldnt fill or wash( fontloader anyway, although you took off the hoses to the pump did you look within the pump for a blockage.(toothpick--- hairpin)
Posted on Jan 30, 2009
  • 1 more comment
  • Ron Coons
    Ron Coons Jan 30, 2009
    please post entire model number so i can research further
  • Ron Coons
  • Ron Coons
    k i looked up your machine,is actually amde by frigidaire. the most common no drain issue is indeed clogged pump,( can you hear it "humm"????), if not i would disconnect the wires from it, hook a meter to it and check for 110v..
Where is the switch located on the front door of front loader washing machine
Hello Friend, that's a great question!
In order to provide you the correct location of the door switch on your Frigidaire front load washer, I will need your model number. The serial tag, which lists your model number, is typically located on the upper front, as you open the door. Thank you! - Z
Jun 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
My front loader does not get no water in it
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
Oct 24, 2012 | Electrolux EIFLW55HIW Front Load Washer...
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
I have a front loader. When I shut the door and
pin on door switch is brocken. look on top of door latch
Feb 12, 2010 | Kenmore Elite 45986 Front Load Washer
Door not locking on front load washer
No reset, sounds like a bad door lock switch. The unit is under warranty, call for service.
Mar 30, 2009 | Kenmore 46462 Front Load Washer
Washer vibrates during spin cycle
Front loaders have to be situated on solid flooring such as a basement or they will vibrate.
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool front loader
please clarify the "some times throughs the switch" part...does the timing switch continue to run even though the machine stopped?
May 25, 2007 | Whirlpool AWM8143 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
