Question about Kitchen Ranges
Trying to install new ignitor (heating element, starter) can't get front off Same problem, trying to get at igniter switches,but can't remove stove top.Kenmore Gas Stove 79077471792
  • Kitchen Ranges Master
  • 8,220 Answers
Try looking in the bottom section.Below the oven. yank out the drawer and look for it in the bottom compartment. guessing
Posted on Jan 30, 2009
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
GE XL44 gas oven
well..that's a gas issue, not an ignitor issue..did you check for the pilot to be active? or is this pilot less?
Apr 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
The gas in the oven goes on then off
follow this instruction. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Ovens
Do you have instructions on how to replace the ignition switch in a honda element?
Remove the electrical plug that is plugged into the fuse box which powers the ignition switch. Remove the two bolts holding the ignition switch in place. Some Honda vehicles have blank head bolts or round head bolts. In this case, you will need to cut a groove into the center of the bolt head with a dremel and use a flat tip screwdriver to remove the bolt. Or you can try removing the bolt using a center punch and a hammer to turn the screw bolt counterclockwise. Pull the ignition switch out of the steering column and install the new switch. Installation is the reverse of removal. Here you can find the quality Honda starter parts http://www.carpartswarehouse.com/carparts/Honda/Starter.html
Aug 25, 2011 | 2004 Honda Element
Pilot light comes on but heat does not come on.
You will need to take out the ignitor, and if it has some black carbon build up you can take a piece of sand paper and remove the carbon until the ignitor is shiny, replace the ignitor and then give it a try.
Feb 01, 2010 | Heating & Cooling
Heating element stays on when turned off
The thermostat (that is the dial that you turn to energize the heating elements) is the only thing that connects power to and disconnects power from the heating element. It is bad.
You can unplug the unit and remove the thermostat. Take it to a parts supplier and get a new one and install it. Your problem will go away.
If you would like to see a wiring diagram...click on this link:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316255301.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
The electric igniter wont stop clicking
damaged ignitor switch, either something spilled on it or it has failed...depending on unit could be a spark module control also. let sit unplugged for a day or two and see what happens.
Jun 09, 2009 | Kitchen Ranges
I'm assuming you're working on a gas stove. Take the top off after removing the burner trim.
Nov 13, 2008 | Kitchen Ranges
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
