Question about Dryers
Drum rubbing on inside walls
Sounds like drum is out of round, but i can't tell for sure. what's easiest way ot get inside for a look
  • Ron Coons
    Ron Coons May 11, 2010
    list the model number for a better understanding of machine.
  • 979 Answers
Go into the back of the dryer. Remove access to back and you will see the drum. Chances are your motor that turns the drum is loose or the shaft or spindle that the dryer spins on is loose from its bracket. Tighten all that up and it should be fine.
Posted on Jan 31, 2009
LG WM 0642 HW Direct Drive Making a thumping sound when spinning and smells like burned rubber. Smoke coming out of durm when front load door was opened.
Hi Paul.
What you're describing is probably the inner drum rubbing on the door seal.
It could be because the rear bearing assembly has collapsed or because the drum is distorted.
Turn the drum slowly by hand and see if the gap between the rim of the drum and the rubber seal stays the same. This will tell you if the drum is 'round' or bent out of shape.
Alternatively, if the drum flops up and down inside the outer drum it would be because of bearing collapse
Either of these situations would require a service visit and parts.
Get a quote...
Good luck.
Nomess
Jan 11, 2015 | LG Washing Machines
PAPER STUCK TO DRUM INSIDE
Here is a copy of the service manual - it should provide instructions on how to reach the drum.
Panasonic UF 7000 7100 8000 8100 Service Handbook
May 20, 2014 | Panasonic Office Equipment & Supplies
New Drum Install - Rubbing
Ken, Don't know if this will be of any help or not, as I've never seen a dryer drum with the felt seal on the front. All of the machines I've repaired, (and that's a bunch), had the felt seal on the rear of the drum, with the front being supported by the configuration of the front panel where the door is located. Mostly the front of the drums were supported by small strips of teflon, or cork, as slides, but that's it. Never had one with felt in front. Is it possible the drum is in backwards?
May 17, 2014 | LG DLE5977 Electric Dryer
Clean heads on VCR
Q-tips, isopropyl alcohol and soft cloth + pressurized air is what you need. Disconnect from the wall outlet, open the cover. Blow the dust out with a few bursts from the air can. Clean all the upright posts along the tape path. On the left is the erase head (unless you have a fine editing VCR) - rub it clean with a q-tip soaked in alcohol - dry with a clean cloth. To the forward right of the round video head drum is the audio head, drive shaft (capstan) and rubber pinch roller. Clean all these like the erase head but use very little alcohol on the roller. Then clean the round video head. Never touch it with your fingers or anything but a q-tip or soft cloth. The actual video heads are in the tiny slots in the rotating part. Do not rub them but just touch a few times with a slightly moist (alcohol) q-tip. The rest of the drum can be rubbed normally paying attention to getting the groove clean.
Nov 11, 2013 | Televison & Video
When i turn the drum it sounds like something metal is rubbing on it, what can that be
the usual culprit is a rogue bra underwire which has gone through the holes in the drum. feel round inside the drum it be still sticking through a hole if so grab it with a pair pliers and pull it back. failing that if you take the heater out you can recover it through the aperture.
Jul 25, 2010 | Neff W4380X1 Front Load Washer
My 96 Triumph Trophy lost rear brakes while I was driving. I pulled over and discovered the entire foot pedal and braking pedal was very loose. The arm bar that connects to the rear brake also had lots of...
the back brake leaver on the rear drum is fitted to a "spline" it may have sliped round if the bolt was not tight or inside the rear drum there is a "cam" that pushes the brake shoows onto the drum this may need looking at look at the rear leaver first,, if its sliped round just take it off and put ot back on further round the spline then re-ajust the brake rod!
Jul 19, 2010 | Motorcycles
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
My daewoo nubira 98 makes a catching noise evreytime the rear wheels spin round while im braking from the rear brakes after ive just had new drums cylinders and shoes fitted. is it because its all new and...
Get your brakes checked by whoever done them.
Brakes shouldn't having catching sounds, I would remove the drums and check for any foreign items. New brakes you would sometimes hear a rubbing sound, but nothing sharp and catching as such.
Check: shoes for foreign bits, even small amounts of gravel etc,
Inside of drums for damage.
Shoe springs are all attached and connected to the right places.
Cylinders are not loose.
This should solve your problem.
Mar 23, 2009 | 1999 Daewoo Nubira
Accumulation of pet hair inside dryer
easiest thing to do ,, if you have a vaccum ,,just vaccum off lint and debris ,,,,
Jan 02, 2009 | Kenmore 63942 Dryer
Dryers Logo
93 people viewed this question
Top Dryers Experts
