Question about HP LaserJet 2840 All-In-One Printer
Paper is coming out wrinkled in one spot
A section of the paper comes out all crinkled each time I print.
    Problem Solver:
  • 3 Answers
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Posted on Feb 02, 2009
How do I stop the paper from crinkling prior to printing in Canon D320
check the whole paper flow. special look out for things in the printer that don't belong there, like a paperclip or screws of paper.
sometimes things fall in a printer and can spot all the fun.
Jan 21, 2015 | Canon Office Equipment & Supplies
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
I need help repairing my copier. The pages are wrinkled when they come out. I was making multiple copies when it paper jammed twice in a row. i removed the paper (no pieces left) and now half of my paper...
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Sep 04, 2011 | Office Equipment & Supplies
My canon Pixma. When it prints, the sheets come out crinkled!
This usually happens when the rollers that feed the paper through the printer are dirty. Because your printer is still rather new, I'd imagine that it is a dust problem rather that ink overflow. what you should do is get a cotton swab and some 99.9% alcohol and clean the rollers. The rollers will look like black cylinders and will be in locations that the paper goes. there are usually 2 just inside of where the paper is, and you find some under the cover where your ink is. Once you have cleaned the rollers, try to print again ans see if it still comes out wrinkled.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
When printing paper comes out all "crinkled" maybe roller problem?
It the paper comes out crinkled or accordion looking then it is your fuser. Check where your the paper comes out of. There might be a piece of paper jammed in there that is causing this. If no obstuctions then it might be the roller on the fuser cracking and cause it to crinkle the paper. The fuser is the last thing the paper goes through before coming out. It "fuses" the toner to the paper.
Apr 26, 2010 | Brother MFC-8660DN 5-in-1 Laser...
The paper comes out wrinkled and makes the printing off, doesn't look nice and clean. The machine even sounds different like you can hear it crinkle the papers
You didn't list the make and model but it is safe to bet that your fuser is used up...call your tech support line for your copier since that module needs to be changed out by a trained technician.
Sep 11, 2009 | Office Equipment & Supplies
Cannon copier/fax is crinkling outcoming paper
Although you did not mention the model of the machine, it sounds like you have a torn fuser film. Needs the fuser rebuilt or replaced.
Printdoctor
Dec 17, 2008 | Canon Office Equipment & Supplies
Crinkled paper
sound like you fuser is bad
Jul 08, 2008 | Office Equipment & Supplies
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
HP LaserJet 2840 All-In-One Printer Logo
591 people viewed this question
Ben Johnson
