Question about Sony Cyber-Shot DSC-S40 Digital Camera
White screen, won't take pictures, battery door won't open!!
I've had this camera for a few years and it's always worked fine. Never been a problem as far as opening the battery door. Today I was taking pictures of my son and I set the camera down (didn't drop it!!) to help him with something and when I picked it up to take more pictures....the LCD screen was white. I turned the camera off and on again. The lens doors opened fine, lens came out as usual, but still white screen. Then I tried pressing the button to take a picture (thinking maybe the LCD screen had given out, but I could still take pictures). Nothing happened. So I tried to open the battery door to take the batteries out (I KNEW it couldn't be dead batteries, because when that happens I can't turn it on/off - the lens stays stuck wherever it happens to be). I cannot open the battery door! The camera has not gotten wet, has not been dropped, chewed on, swung around...nothing. I have opened that battery door MANY MANY times, so I know how to do it, but it will not budge. Even my husband, trying to use brute strength, could not get it open. I really can't afford a new camera right now - but my birthday is coming, so maybe if I hint to family I might get one, but the batteries in it are rechargable and I'd like to keep them if I can! Any help? Thanks, Shelly
  • lolema1 Jun 23, 2008
    I press on both sides of the display on the silver part and it comes into focus and white screen disappears.
    Still can't open battery container.
    Problem Solver:
The LCD screen has just come unattached. Take a pencil with an eraser and press on the lower right corner of the LCD screen. You may have to tap it once or twice, but the screen will come back on. As far as the battery door, it sounds like it is stuck on something. Might want to try tapping the end of it to see if it comes loose.
Posted on Aug 08, 2007
    Genius:
  • 2,985 Answers
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Posted on Jul 31, 2007
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Cannot open battery door, white screen, can't take pictures
Looks like a new camera for your birthday then.
P100 was working took 1 picture and froze open. white screen won't charge
Perhaps you have an empty battery?
Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it.
Switching of a camera causes it to start again, like a cold boot from a computer.
Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
May 05, 2014 | Nikon Coolpix 4600 Digital Camera
Automatic overexposure all pictures are white
try cleaning the contacts on the mem card and inside the slot with a q-tip and rubbing alcohol.
Jan 28, 2009 | Casio Exilim EX-Z750 Digital Camera
Z710 Camera quit working
Pry the battery contacts " in bottom of camera" up GENTLY" with a small flat head screw driver. They bend easy causing this problem. The force from the battery door can cause this. Always use the "rechargeable" batteries, and make sure it is fully charged. I'll bet anything it will work then. Also. clean the contacts top and bottom with a Q-tip, using a little dab of white vinigar on one side, then dry using other side of Q-tip.Then turn on camera without memory card. Kodak cameras love to eat batteries. The older they get the worse. You might have to repeat this every week or couple of months.
Jul 27, 2008 | Kodak EasyShare Z710 Digital Camera
CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Jul 11, 2008 | Canon PowerShot S2 IS Digital Camera
A White Screen!
I had the same problem a few months ago. Best bet is take it to get it fixed. If you still have a warrantey it won't cost you a thing. Good luck!
Feb 29, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
White pictures, low battery life, few pictures
I glued a small peice of plastic under the flash and above the camera lens to shade it from the flash when it goes off. I then only had 2 pictures out of 40 that showed a white picture. The plastic peice only sticks out about 1 inch and didn't affect the flash on the subject. I also drilled holes in the bottom and hooked up a 6 volt tractor battery to it this gave me over 1 month of battery life with another identical camera
Jan 21, 2008 | Moultrie MFH-DGS-200 Digital Camera
Big Problem with Samsung Digimax S500 PLEASE PLEASE PLEASE HELP!
first try to do the ff:
-try to power reset
(take off battery for 1-2 mins & put battery back)
-BP tried using fresh batteries
(try to replace battereis for your camera)
If you ahd tried those options, i suppose you camera needs service now, contact samsung back, do the ff:
-go to samsungcamerausa.com
-click on customer service
on the upper right portion of website
-provide product code and e-mail address
-provide all other necessary information
in registration process
-take note of service center address
-read all shipping reminders
-send camera to service center address provided
samsung service center will do the repair for you camera or if the problem is unrepairable, they will send you replacement camera, if its still udner warranty. tried this option and now my camera is working.
Jan 03, 2008 | Samsung Digimax S500 Digital Camera
Batteries Dying Quickly
Change the internal rechargeable battery.
Dec 01, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
162 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
