Question about Water Heaters
Just curious what is the reason they say do not use thread tape on compression fittings for eemax units
  • 56 Answers
The tape gets in the system and contaminates and clogs things
Posted on Jan 30, 2009
Fuse for eemax water heater 24027 You should have an electrician install breakers (3) and wire unit. the unit is113 amps max draw. This is not a homeowner istallation.
Sep 24, 2017 | Eemax Water Heaters
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
No water coming out from outlet.
What product? eemax sp2412/
Is this new installation or older installtion that worked before?
Have you cleaned the inlet water filter?
Hs unit exposed to hard water?
Has unit been delimed before?
Have you disconnected supply line under sink to see if problem is faucet?
Aug 31, 2013 | Eemax SP2412 2.4kW 120V
My eemax tankless water heater turns on for a few seconds then turns off.
Couple it a brand new unit with this issue or existing unit that just developed this problem?
Dec 11, 2012 | Water Heaters
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
Main water line to house. Changing shut off valve. New shut off valve has compression fittings. Will teflon tape interfere w/brass compression ring inside the fitting? thanks Brian
I would try to tighten it up without putting tape on it. The ring will compress into pipe when you tighten it to form a seal.
If then it try's to leak you may apply tape or a paste type sealant to stop drip.
May 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Eemax SP3512 not works intermintently, more off than on.
you have a clogged filter turn off the water on the unit on both sides, right below the unit there are 2 caps one on each side take the cap off there is a filter in side, clean it and reistall it that should take care of the problem, you might want to flush out the system while your doing this also
May 26, 2009 | Eemax Instant Water Heater 120V SP3512
My circuit boards keep burning out.
Sounds like you are either getting power surges to the unit or there is an excessive amount of moisture around the control board. There also and probably is a short somewhere in the unit.
Apr 07, 2009 | Eemax EX280T2T Series 3 Whole House...
Slow leak drips from bottom of 4 year old model
You can probably repair this by removing the fittings and replacing any plastic compression rings with new ones. Everything else can be cleaned with grade "0000" steel wool. This will get rid of any deposits without damaging the surfaces. ! or @ careful wraps of Teflon Tape to the MALE threads will help get a good seal.
Feb 04, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Water Heaters Logo
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
