Question about Garmin StreetPilot C330 GPS Receiver
Question about battery for Whitesox
Thanks for suggesting that I remove the battery and try to reconnect it. I don't know how to open the unit to remove the battery. Could you please advise. Thank you.
Hi Mzr119 Could you open that product? I've a c550, and looks like same. I opened it. So u have a silver decoration around the display. U can remove that a small screwdriver and under the decoration u can open it! U must be careful, because this decoration not too strong. Good Luck! Noroo Ps: I opened my Streetpilot c550, because inside Li-Ion battery unrechargeble. I wanna buy a new battery, but I don't know, where and how. If somebody can help me, i will say thanks for him. ;-)
Posted on Jul 28, 2007
SOURCE:
Replacing keypad smh9187st
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
Jan 06, 2013 | Samsung Microwave Ovens
Samsung Microwave SMH9187 error message (?) 5E
Aug 15, 2012 | Samsung SMH9187 Microwave Oven
Unit will not turn on after power down for 3 days.
Assuming you are running on mains, remove battery and try without battery installed.
Try removing mains and battery power and press down on the power button for 30 secs then reconnect mains power and try again.
If this does not work and you know the Power adaptor to be working, I'd suggest its a main fuse in the laptop gone
Dec 29, 2010 | HP Pavilion dv6000z Notebook
I need to disassemble an HP Photosmart C8180 to get at the CMOS battery. I have the very common 0xc18a0401 Ink System Failed and because I have the C8180 I cannot do with the various suggestions on this...
Hi there you can try this may work,
Solution one: Reset the product
1. Without turning off the product, disconnect the USB cable from the rear of the product.
1. Remove the cartridges from the product.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the cartridges, and then close any open doors on the product.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
9. If you have completed all the steps listed above and are still experiencing a problem, you need to service the product.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | HP Photosmart C8180 All-in-One InkJet...
Cd player on 2001 lincoln ls - cd error when i press load button
My father inlaw just purchased a 2001 lincoln, with a six disc changer, Question is he loaded the unit ,and now he wants to eject the cd's and the changer won't open? any suggestions thanks
Jan 06, 2010 | 2001 Lincoln LS
Vectorlite 1.5 million candlepower with a dead battery. How do I get the lite open to remove the battery? Thanks, Jim
It's in this version of the owner's manual:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC119SH.pdf
Looks a little different, works the same. Now... where did you get a replacement battery?
Dec 21, 2009 | Vector 1 Million Rechargeable Spotlight
When I turn my V6000 on, I have power lights and the fan starts for 5 secs then shuts off. Nothing appears on the screen!
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
[email protected]
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
Jul 09, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
K800i cannot open when im trying to open!!some people help me!!
hi thanks for using fixya!!
Is the problem is you cannot turn on your phone? try to remove the battery and install the battery back again, they try to turn on the power, if doesn't open, try to recharge it, if the recharging is not responding, perhaps the problem is with your battery or charger.
I suggest that you bring your phone to the service center.
If you need further assistance, let me know.
pls rate me positively! thanks!
Apr 03, 2009 | Sony Ericsson K800i Cellular Phone
NAD T762 stuck in standby
Remove the power plug first, try to find the Battery inside the unit,Remove it, just for a minute, or two, and put it Back, hope it work again.if you don,t find in the users manual ,how to reset !
Oct 17, 2017 | NAD T762 Receiver
Garmin StreetPilot C330 GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
