Question about Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11)
Green Power light flashing
Hello, I need help fixing my router. The green power light is flashing. Can't get to the linksys page by putting in ip address 192.168.1.1. When trying to download the firmware, I don't know how to do a .bin file.
  • 4 more comments
  • Wanda Edwards Jul 28, 2007
    THanks for the suggestions. I have tried all, resetting the router but have been unable to log in to the ip address 192.168.1.1. Can someone tell me how I can get to this point. I still can't upgrade the software either. It keeps saying "Windows cannot open this file". It is a .bin file. I have winzip downloaded but to no avail. Somehow I was able to get to the "Tftp" area where I put in the ip address, the password, and the file, but when I press "upgrade" it fails. It does it 3 times and fail again. What am I doing wrong. So as u can see, I can't even download the software or put in the ip address in the browser to upgrade that way. If there is someone that can help, please let me know. Also, I am very inexperienced with this and computers, so please if u can offer suggestions, please put it in laymen's terms so that I can understand step by step. Thanks so much for your help.
    I keep getting a response "unable to get response from the server" when I try to do the upgrade thru "Tftp". It tries 3 times and fails each time. Any suggestions?
  • joge Dec 22, 2007
    have a linksis WRT54GP2A-AT router supporting at&t call vanyage; power light continues to flash; suspect firmware update needed; unable to obtain from linksis or Call vantage; does anyone have this specific firmware file?
  • akkie_18 Aug 18, 2008
    same issue not getting IP automatically and Power LED continiously blinking and unable to ping router or not getting setup page
  • cjs__ Feb 04, 2009
    basicly all the ports are linked together inc the WAN port(HUB) power light flashes cant get on to to it by IP and it will not give out a wireless signal at all or IP by DHCP,
  • pabloscan Mar 22, 2009
    Power led constantly blinking. All other ports blink too when connect the net cable. No wireless signal. No Router adreesing. Can´t connect to the router web page. No response to a hard reset. I´m afraid my router had broken down.
    Brigadier General:
  • 6,966 Answers
Hi, Have you tried a hard reset? Your model has a small reset button at the rear between the Internet/WAN connection and one of the antennas (Press for 10 seconds +). Also flashing power led is an indicator of firmware problem which might have been caused by a failed firmware upgrade/update. Instruction on how to correct this problem is also included in the firmware upgrade/update. A more detailed instruction is in the User Manual. With regards to firmware update/upgrade , pls be reminded that firmware is very version specific. To locate the version number, you have to look underneath the unit and download the appropriate firmware from LinkSys website. (http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859878881&packedargs=sku%3D1115416826220&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7888126220B03&displaypage=download) The download is a zip file which you have to extract to a folder. The .bin file plus instructions as well as specific instructions on how to make the power led stop flashing. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Posted on Jul 28, 2007
  • Louie  Role
    Louie Role Jul 29, 2007
    Hello again,
    Let's try doing it based on your reply:
    1.unable to log in to the ip address 192.168.1.1.
    if the firmware is corrupted (and it seems so) the unit will not really let you do much of anything.
    2.I still can't upgrade the software either.
    same reason
    3.It keeps saying "Windows cannot open this file". It is a .bin file.
    The code.bin file is not for windows use but is the firmware upgrade/update of your router. It is intended to replace the existing firmware inside your router and will have to be used in conjunction with tftp.exe. It has nothing to do with windows.
    4.I have winzip downloaded but to no avail.
    Winzip was only needed to unpack/uncompress the downloaded befw11s4v1-1442z_fw.zip, after that it will not have any function in the firmware update/upgrade/repair.
    5.Somehow I was able to get to the "Tftp" area where I put in the ip address, the password, and the file, but when I press "upgrade" it fails.
    Since you were able to do this, that means you were able to unzip the files; open, read and follow the Firmware Upgrade Instructions.doc and double clicked on the tftp.exe
    6.What am I doing wrong.
    I don't think you're doing anything wrong since you are closely following the instructions of the Firmware Upgrade Instructions.doc
    7.I can't even download the software or put in the ip address in the browser to upgrade that way.
    This is where it gets to be a bit tricky.
    Please make sure that your PC's Lan Card or NIC is connected to any of the 4 ports LinkSys BEFW11S4 rear with a networking cable; if yes, then another light should be lighted in the front panel of the LinkSys indicating that your PC is connected to that port number; also at the bottom right of your desktop in your system tray, the networking icon should indicate that you are connected and must not have a red X mark.
    Going back to the LinkSys, all the other ports with no lan cable connected should not be lit. If there is any port indicator lighted but with no cable connected or if the port where you connected your lan cable does not lit, then the LinkSys should be sent in for major repair of replacement.
    If all is well except for the power led flashing, please proceed to make sure that your PC's IP address is set as follows and not Auto Obtain:
    IP Address: 192.168.1.50
    Subnet Mask: 255.255.255.0
    Gateway: 192.168.1.1
    You can change to the above setting by going to Start/Control Panel/Network Connections;
    Right Click on the Local Area Connection and left click on Properties;
    A new window will pop up Local Area Connection Properties -
    Scroll to Internet Protocol (TCP/IP) and highlight it, click on Properties mid right;
    A new window will pop up Internet Protocol (TCP/IP) Properties -
    Tick Use the following IP address;
    Use the above numbers;
    Click OK and then the other OK
    Run again the Tftp.exe file and and follow the Firmware Upgrade Instructions.doc
    8.I keep getting a response "unable to get response from the server" when I try to do the upgrade thru "Tftp".
    Let's see if this shows up again after following #7.
    A reminder, the firmware.zip file should match your version number, a user manual with a more detailed explanation of the above may also be downloaded from the same site.
    If you still get a response "unable to get response from the server" when I try to do the upgrade thru "Tftp", I am afraid that your LinkSys is really due for major repairs or replacement.
    Lots of luck and Cheers.
    Problem Solver:
  • 5 Answers
Solution 1: Reset router by pressing reset button using your finger or with a tip of a pen or paper clip for at least 30 seconds. This will reset your router to the default settings. Solution 2: Once you are able to log into the built-in Web server to IP address 192.168.1.1, change default settings for security and use encryption if possible. Once in the settings screen, look for the update firmware setting and upload the .bin file you downloaded from the router's manufacturer.
SOURCE:
How do I Access the router’s web-based setup page?
Hello
you need to know the routers ip address or have the software. For most things the ip address will be 192.168.1.1 . You simply type that in your web browser and a page will come up.
you may need to go to the linksys site to find the default ip address of your router. But I would try "192.168.1.1" first.
Have a great day
Nov 25, 2010 | Linksys Wireless-N WRT150N Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
My Belkin F5d82334v3 router flashes orange continuously
Contact belkin for the IP address to change your router setting internally. For example: Linksys is 192.168.1.1
Putting this address in your address bar will dial you into your router setting if you have a Linksys router. Each router manufacturer may have a different IP address. Hope this helps! Good Luck!
Mar 15, 2010 | Computers & Internet
My router doesnot see me internet
What lights are lit on the router? Is the internet light red or green? Can you access 192.168.1.1 (the usual I.P. address for Linksys routers)? Do you have a static or dynamic IP address from your ISP? (You need to go to the router page to change it but the default is DHCP.) With some cable modems and all DSL service, you may need to change the local IP address to 192.168.2.1 and then save the settings. Next renew your computer's IP information (either from the command prompt or by rebooting) and then point your browser to the new address for the router. One way to check this is to see if you have change the settings is if you see an address of 0.0.0.0. If you do change the settings you may need to power down both the modem and the router before trying the internet connection again. The default router user name is left blank and the password is admin. You can change these at the web interface.
My reference is http://www.linksysbycisco.com/US/en/support/WRT54GC
Also double check that your computer sees the internet without the router, just in case you have a bad router.
Aug 26, 2009 | Linksys (WRT54GC) Router
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Trying to get my linksys wireless router to go on dsl .
All you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
May 07, 2008 | Linksys Wireless-G Broadband Router
Linksys BEFW11S4 802.11b Wireless Router/Switch + WMP11 PCI Card (BEFW11S4 + WMP11) Logo
8,498 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
