Question about Kenmore 62602 Electric Dryer
Wont dry very fast
I have a kenmore 90 series that takes forever to dry cloths. It dryes the cloths but it takes much longer than normal. The filters are clean and the dryer vent is clean as well. Do these driers have more than one heater element?
  • 1 more comment
  • yamahawillie Jan 30, 2009
    Hummm... I took the cover off the back and found one of the 110 legs on the power in has some green funk built up around the connector end that screws to the dryer itself. Could it have a bad connection here and cause this problem?
  • yamahawillie Jan 31, 2009
    Where is it??? :)
  • kunjah8 Feb 01, 2009
    I have same problem, it takes almost twice time than in other dryers. I was trying to open bqack cover and noticed back cover is welded on the top. I was wondering to break that welded part or there is other way to open this back cover.
    Kunjah8
  • Kenmore Master
  • 8,220 Answers
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Posted on Jan 30, 2009
  • Dan Webster
    Dan Webster Jan 30, 2009
    Naw I don't think so, more than likely a blockage or control thermostat issue from what you is describing.
  • Dan Webster
    Dan Webster Jan 31, 2009
    It mounts on the blower housing and is accessed by removing the rear dust cover on most machines.Right next to the thermal fuse.
My dryer is working and heating but it's taking more time than usual to drye the clothe
hello vic.... when it takes longer to dry the clothes check the vent pipe and the outdoor vent for lint buildup! Joe
Mar 14, 2011 | Dryers
I have a Kenmore Elite dryer. It is not drying the clothes properly. It takes a lot longer to dry the clothes. One time it dries fast the next time it takes forever. Any ideas??
it sounds like your dryer stat real name t.o.c. you will need a engerneer to do this the job should cost no more then £40 pound ring a round for a call out the cheapperst is not all ways the best ok so make sure you ring 4 to 5 guys just tell them the problem and they should say the same if they dont get back to me and i will try for you see if i can get some one to help you in your area ok
Feb 03, 2011 | Kenmore Elite HE4 Electric Dryer
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
It takes longer to dry your clothes you have to restart the drye
first clean the pip from the unit to the outsde vent.
then inside your unit there are 2 felts that need to be cahnge, over time they go bad and the heat run out the drum and you can feel the hood is hot but it still not to good . it will save you electric bill when you fix it. :)
Dec 31, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore electric dryer 110.60712990 Series 70 heats but does not dry the clothes. A friend with a meter came over and said that there is 9.8 ohms resistance on the heating element. Is this within normal...
Your heating element is good. It should read between 9 to 13 ohms. If the heating circuits are working, then you don't have a problem with the heating circuits. The numbe ron cause of drye heat related problems, or longer dry times, is poorly installed, or clogged ventilation. A simple test to try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the exhaust should be forceful and warm (about 140 degrees).
If the air flow is normal, and your clothes dry normally, the problem is with your exhaust ducting from the point where it leaves your dryer to where it exits your home. I would recommend you inspect the entire length of your exhaust ventliation to make sure it is free of kinks or clogs if this is the case.
If the air flow is weak, then the problem is INTERNAL to the dryer. The most common source of the problem is a clog in the blower fan housing preventing air to flow properly. Remove the blower fan housing cover and clean as necessary. Make sure the blower fan can turn unobstructed.
Let me know if you still have problems. I hope this helps you.
Jun 25, 2009 | Kenmore 63942 Dryer
I have a Kenmore 90 series that i have to run through drying cycle twice before the clothes get dry"
try washing the lint screen it gets blocked if you are using fabric sheets
Apr 28, 2009 | Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Kenmore 62602 Electric Dryer Logo
268 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
