Question about Philips 46PP9302 46" Rear Projection Television
Blue color is ober screen
My tv get good color but ouly the blue color looks like aura i am trying ajus but i can get you know if is the capasitors problem my tv is ouly4 years old i think is the blue rct can you helme thanks
  • Philips Master
  • 3,459 Answers
It may be the fluid in the CRT or convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common prblue color is ober screen - 2c07611.png/>
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Feb 05, 2009
The colors are not sharp any more and they all blend in together, its either too much red or too much green or blue what can be the problem?
manual convergence should fix the problem if it does not the set most likely either has a bulb burnt out or a bulbs power / focus needs to be adjusted by taking off the panel and finding a 6 screw control panel
should look like that 3 screws in a row on top of another three screws each of thees control the power and focus of each color this is a somewhat delicate process and is a huge pain on larger tvs that you cannot completely see the picture or color while you are directly under in front of it so I had my gf come in the room and sit across to let me know which color was doing what if you dont have someone you will need to check after each adjustment
now the diagnostic
as i said each screw controls a colors power and focus the focus is used if you see an outline of a color around pictures if everyone looks like a dead jedi with a blue aura around them the blue focus needs to be adjusted and so on for each color if you skies or blue screens seem feint your blue power probably needs to be turned up and so on for each color
if through the course of this you can see the bulbs and notice one is out your probably looking at dealing with the color issue until the time you can purchase a new tv as the cost of the bulb and the technician needed to install it as they are wired to a circuit board and requires technical knowledge and tools
hope this helped
Robb
Jun 12, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 60" HDTV
If the blue looks like an aura of light around the picture then it is likely to be a problem with the color wheel, probably it should be replaced.
Try first doing a color auto balancing (magic focus) and see how it goes, probably you will need to replace color wheel.
Oct 14, 2008 | Philips 60PP9202 60" Rear Projection...
Color is off and there a light blue line through out the screen
now the diagnostic
hope this helped
Robb
Apr 29, 2010 | Mitsubishi VS-45607 45" Rear Projection...
I just auto convergence my zenith tv and it fixed but still 3-D
Ur tv convergence ICS are dead.That why ur colors lines green,red,and blue are not linning up,and the colors look like 3-D pic.Must have soldering tools,and know soldering to fix convergence problems.Must replaced 2 STK convergence ICS and some or all of it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 29, 2010 | Zenith R56W36 56" Rear Projection...
Covergence problems or alingment , its has three colors without alingment please help me!!!
now the diagnostic
hope this helped
Robb
Apr 29, 2010 | Zenith R57W46 57" Rear Projection...
Odd picture....
Yes, your convergence is off. There is a function in the menu for adjusting these propoerties. It is supposed to be done monthly but rarley is. If it is ten years old or more, the cooling fluid in the projection tubes can get low, causing fish bowl effect. Not a cheap job and time intense. Try adjusting the convergence first. It gives you three screens to aling each color then save. Good luck!
Jul 25, 2009 | Televison & Video
Red "aura" in the middle of my 55" Phillips Magnavox
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
Blue aura at bottom of screen
Check 2 things.
First, make sure the lenses, mirrors, and back of screen are spotless. Second, look into the CRT's when the set is running. There is a real good chance cooling fluid leaked out or got cloudy. It's supposed to be a clear oily fluid (a combo of glycerine, water, sometimes methyl alcohol and preservatives) and will be around the tube and chassis if leaking. Rebuilding the assembly is possible (Magnavox had the same problem, as they were a Hitachi chassis), but the CRT is usually damaged. If I have to rebuild them, all 3 are done in one shot - new fluid, seals, filler spout.
Besides that, the tubes are cheap and lose their sharpness with age (gets gassy). Had real problems with that and the only correct solution is to replace all 3 tubes. You could cheap out with one tube, but setting the color balance (grey scale) is often difficult if not impossible.
Good luck,
Mark
Nov 09, 2008 | Hitachi 60V500 60" Rear Projection...
Images have a blue aura
the screen has been magnetized once before
Mar 06, 2008 | Panasonic PT-65WX51 65" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
