Question about Cobra 148 GTL 120-Channels Base CB Radio
Uniden president grant stops transmitting wait 1 or2 minutes and it will transmit for a little bit then does it again never lose my recieve thank you for your intrest
  • 1 more comment
  • grandadmac50 Jan 30, 2009
    we checked the final and the driver and they are good
  • grandadmac50 Feb 02, 2009
    it stops transmitting on side band the same as am this is my uniden president grant it is not a xl if you could see fit i could use the mike wiring for a regency 501 mobile it is 5 pin i cant find it any where thank you for your help with my grant if i get it working again i will be a happy man thanks ever so much grandadmac 50
  • grandadmac50 Feb 03, 2009
    I dont have a credit card so i cant pay for any questions again i want to thank you for the info about my grant it does that on side band it just takes longer you have a fine day
I cant afford 20 dollars to fix that radio your add said free i am laid off the old grant will have to waite i am not a teck have no idea what is wrong thank you for your time sorry to bother you ihave a good ole cobra29 that i talk on now grandadmac50@ yahoo.comm
Posted on Jan 30, 2009
  • 32 Answers
This sounds like the AM regulator has lost All of its smoke.(thats what electronic parts are made of) If this is A Grant the AM regulator is located in the rear right hand side of the radio.If it is a grant XL this is located on the very back of the radio on its on little circuit board.check this part part to see if is your other way that you can tell if this is the problem when it stop transmitting check it on side band (LSB or USB) to see if it transmitt.If it does that is most likley your problem.
Posted on Feb 02, 2009
What should i look for if my uniden presiden jackson cb has no transmit or no recv
voltage regulator. is it a ss (superstar) jackson or president jackson?
Dec 21, 2015 | Uniden Radio Communications
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
Uniden president ssb base no transmit and no receive how to fix
Have the mic checked first to make sure wired correctly and or wires not broken where connect to plug----also check to see if same on SSB and Am.
President what? Madison, Lincoln etc.
Apr 23, 2012 | Radio Communications
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Uniden grant lt transmit and receives normally but when i key up on AM the AM power regulator gets hot quick i changed out the driver and final and replaced the regulator still does the same thing and it...
Sounds like a "short" if it affects modulation + power. Try to inspect board with magnifier for solder bridges, and bad resistors. Change a few resistors near back with new ones. take out slugs near back finals like L10 or L20's not sure if its same as Uniden Pc68xl. but try that. I found turning L19 up to top gave great Modulation. clip D9, Sread coils 1/16 inch in back. Try to get lower carrier. Carrier does not mean anything much. Modulation is what you need. With less Carrier it may cool down that chip. It may be too wound out.
Mar 26, 2011 | Uniden GRANT LT 2-Way Radio
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
How many amps does the Uniden President LTD 715 need to operate/ transmit?
A 6 amp fast blow fuse is usually enough for any marine VHF radio.
Jul 01, 2009 | Uniden Boating
Cobra 148 GTL 120-Channels Base CB Radio Logo
486 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
