Question about Magic Chef CER3725AA Electric Kitchen Range
Cant open oven door!
Self clean is complete, now I cant get door open, not sure which way to take lever left or right, but scared i will break it. HELP...
  • 716 Answers
Unplug The Stove From The Power Source For A Minute Then Plug It Back In. Then Check it Again
Posted on Jan 30, 2009
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    I have misplaced the manual for my oven and I need the self cleaning instructions. Model # RF365PXDQ0 Serial # FE2007966
    First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
    Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
    The manual is available here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203189075.pdf . If the direct link doesn't work, start here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number and then click Go.
    I hope this helps.
    Apr 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
    I cannot open the oven door to my GE oven. I had to move a lever from left to right. After cleaning, I moved it back to the position it should be in (while not cleaning) but the oven door is still...
    Most of these self-cleaning stoves have to cool down before the door can be opened. This is a safety feature. Has the oven completely cooled down? If so you could try unplugging it wait 15 second and plug it back in. This might reset the lock.
    Feb 28, 2011 | Ovens
    Our Kenmore oven door also remained locked after I manually switched the cleansing level just over the oven door to the right side in hoping of locking the oven door to prevent my 19M daughter from opening...
    You are correct. The locking mechanism has a heat sensor which will not allow you to open it while its hot. You should only use the lever while in self-clean mode. It will not let you open it because it heats to about 900 degrees during self-clean and could cause serious harm if anyone opened it while it was that hot.
    May 21, 2010 | Kitchen Ranges
    How do I self clean my gallery series fridgidaire?
    Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
    Jan 14, 2010 | Kitchen Ranges
    I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
    or
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Gerangeoven door won't open
    Is it in time bake?
    Oct 04, 2009 | GE Ovens
    DOOR SHOWS OPEN BUT IT IS NOT
    After self cleaning the range the door won't open....
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Hope this may help;
    DON'T FORGET TO HELP
    Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
    Oven Door is locked and will not open
    On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
    Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
    Magic Chef CER3725AA Electric Kitchen Range Logo
    119 people viewed this question
    Top Magic Chef Kitchen Ranges Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
