Question about Samsung RS2630SH Side by Side Refrigerator
Fridge has been working great then this morning no power.
Fridge is dead. power is throughout house. no lights nothing. please help as all food is being wasted and there was alot of it.
  • smellytoosh Jan 30, 2009
    Yes sorry i should have mentioned that i tried that and the power point is fine. Do fridges blow fuses??? sorry to be ignorant but never had a fridge stop working
  • 410 Answers
Try plugging your refrig into a different outlet, or plug something else into the outlet the refrig is plugged into to verify power to the outlet.
Posted on Jan 30, 2009
  • peyton thompson
    peyton thompson Jan 30, 2009
    well they can blow house fuses but they dont have internal fuses.
    since you dont have any lights or operation at all my guess is a wiring issue that would probably require a qualified servicer to track down for you. for safety sake i would reccomend leaving the unit unplugged until you have it repaired. sorry i couldnt be of more help..
Fridge always running. Refrigerator freezes food at lowest setting.
Here's the manual you need with the parts lists. On the first page, it has "parts" numbers for the other manuals you may need that I'm sure you could also find online with a Google search.
Here is the website that carries the part: You might be able to find the parts elsewhere online.
Jan 22, 2014 | Frigidaire FRT21H8 Top Freezer...
Fridge works intermittently
Some Of These Fridge Freezers If You Open The Door For The Freezer There Is A Switch Between The Fridge And Freezer Door Mine Done The Same And I Had To Replace That Switch It Turns The Fan On When Door Is Closed And Off When Open
Nov 04, 2013 | Refrigerators
In that case you need to check this
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Jul 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
Fridge not cooling! But the Fan and light is working! HELP!!
Sounds like you have caused a leak in the sealed system and the coolant is no longer inside it. You will need a professional to fix this.
Apr 13, 2009 | Jason Natural Cosmetics Jason Forma...
Refrigerator no power
Plug some other device into these same outlets or use a volt meter to verify power at the outlet.
You definitely have a house wire problem if the interior light does not come on and the bulb is good.
Also check 120 volts power at the fridge cord where it attaches to the terminal box.
Feb 21, 2009 | GE PSS26SHRSS Side by Side Refrigerator
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Oct 21, 2008 | Frigidaire FRS26R4A Side by Side...
Fridge/freezer warm, no fan, light's on
you can remove back cover feel the compressor, is it hot?? perhaps it overheate.
Feb 24, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
334 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
