Question about Philips DVDR3455H/37B
Downloading from hdd to dvd+r ?
I downloaded footage from an external device (camcorder) on to my hdd i wanted to download it on to a dvd+r disk . I put in an empty disk to download but it keeps telling me the disk is full when it has nothing on it.
    Problem Solver:
  • 6 Answers
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Posted on Aug 13, 2007
SOURCE:
The camcorder is not working, comming up with hdd format error. I've lost all my footage from our trip to disneyland and it will cost about $400+ to recover if they can recover. The other problem i have is...
You are finding the same problems as most Hard-drive and DVD recording cam user these media's simply do not work, they are too un-reliable to put your special holidays and good events on, the only way is TAPE cameras (unless you are not too bothered about loss of your special times.
Sony have dropped DVD cameras already after 3 years of people having problems, and I hear that the hard-drive models will go the same way next year when new tape models come out in the spring.
Jul 05, 2010 | Sony HDR-SR10E HDD Camcorder
Hitachi dz mv230a DVD CAM - can't copy video to computer (WXP Pro)
Make sure its pluged in to a powersource and try again, you should see the camera in my computer.
There might be fault in the camera.
May 18, 2008 | Hitachi DZ-MV230A DVD Camcorder
JVC DR-MX1 loading error - how can I retrieve hard disk hdd conte
well, i sympathize with your problem- it may be a bit expensive, but there are 'data recovery' services available on-line. if the data on the hd is still intact, then they can either 'burn' it to dvds, or transfer it to an external, usb hd. then, if your pc has a dvd burner, you can archive the content to dvds! store them in hard case holders-make copies and store them in a safe place! fire-resistant safe, safe deposit box, with a trusted relative or friend, in case the originals become damaged. also, use the external to archive any future pictures, or videos- then back them up on dvds! would suggest 500GB-1TB usb 2.0 external,if your pc can support it! $85-150. cheap!
might send the external along with the 180MB to whatever service you decide to go with, that will save some $$, in the long run. (or it should- research what the recovery services offer!).
good luck!
Oct 04, 2009 | JVC DR-MX1S DVD Recorder/VCR
Lost recordings
It is required to finalize the recording in the Camcorder in order to play the recording in any device like DVD player or in Computer.
First finalize the recording in the Camcorder and then try playing the DVD in any DVD player.
After finalizing the DVD, a DVD player will be able to play the disk.
Refer the User Guide page # 44 of 139 for the instruction to finalize the recording in the Camcorder.
Check the link give below to download the User Guide (Operating instruction):
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD108
or
http://www.docs.sony.com/release/DCRDVD108.pdf
Good Luck!!!!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
How do I download my film footage from my Sony Camcorder?
AV output or USB
AV output needs a capture device
USB connection the computer should see it as a disk drive in MY COMPUTER icon that you can transfer the data as a mpg file to the Cdrive in any folder.
Jul 24, 2009 | Video Cameras
Cant download to dvd
Hope the following helps. I had the same problem and then a friend recommended that when you plug in the camcorder into your PC, press the "DVD copy" button on the unit and also when it comes up on your view finder. The video cam suite program automtaically comes up on PC screen and you can then proceed. My problem know is that I also used the cam corder to record video footage on an SD card but the software only allows copying of the motion videos stored on the hard drive. Does anybody have any suggestions how I can get around this without having to pay $60 per hour of footage for the professional camera places to do it?
Jun 05, 2009 | Panasonic SDR-H40 HDD Camcorder
Download video from camcorder to computer.
buy a dvd player/recorder. plug the camera into your usual jacks(rca) and record.. you can then use that disc on your computer to do whatever editing you want.. that is if everything is compatible
Jun 15, 2008 | Sharp Viewcam VL-A10U Camcorder
JVC Camcorder HDD Can't burn to disc or download to PC
Do you have all the manuals the first manual on this site talks about downloading movies and burning then to DVD.
JVC manual site
Download2.gif and install adobe reader2.gif, if needed
Right mouse2.gif click and "save target as" to save each manual to a file
Dec 15, 2007 | JVC Everio GZ-MG21 Camcorder
Philips DVDR3455H/37B Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
