Question about Samsung PCN5425R 54" Rear Projection Television
Hitachi 43DX20B HDTV with a screen flashing problem.
I have a HDTV that when there is a lot of action in a show or movie the screen and sound flashes out. The screen goes black for about 3 - 5 seconds and comes back in. The picture is a beautiful picture but when there is a lot of gun fire or camera flashing in the movie it blanks out, the sound and everything goes out. Has anyone seen this before?
SOURCE:
SOURCE: Samsung DLP won't turn on-rapid clicking sound, lamp light blinks
it was bad bulb
Posted on Mar 04, 2009
  • 8 Answers
SOURCE: screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Posted on Apr 16, 2009
  • 304 Answers
SOURCE: Samsung DLP HL-R6167W - works fine for about 5
There are three possible parts causing the problem. First, the Main or Digital bd is bad, Second, the DMD bd is bad. Third the Color Wheel is bad. You need a trained Samsung tech to have a look at it.
Posted on Jul 16, 2009
Slinteriors
  • 8617 Answers
SOURCE: Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Posted on Aug 28, 2009
SOURCE: lamp goes off and tv shuts down after lamp replacement
when you put the lamp cover back on you need to make sure that the little black switch is in the up position (it is spring loaded to go down)
Posted on Oct 03, 2009
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
Dish network 222
Sounds like power supply problems, mak sure plug goes directly on a good tight wall scocet for full 120 volts and enought amperage to run your unit, to many devices may drain your power.
Nov 10, 2012 | DISH Network Vip 222k Hdtv Satellite...
Rca tv/dvd combo L32HD32D powers on and for 2 seconds shows, Please Wait, on the screen then goes black. What do i do?
After the screen goes black, do you still have sound or you have none but a blank screen? If you have no picture and sound does the power LED in front of the tv indicate that the set is on, or does it go into standby? Please provide this info so that I can help you with your problem.
Sai.
Aug 15, 2011 | RCA L32HD32D 32 in. LCD HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Screen goes blank momentarily
cover up the infrared remote sensor on the projector. The heat of these colours or something might be messinf with the infrared remote sensor. TRy this and see what happens. It may just be bad contacts. Some projectors just cant handle stuff like this. Some were meant for presentations and presentations only. BUt seriously try covering the remote sensor to see what happens. If it is an older projector the infrared signal detector might be sensitive to bright light or stuff like that.
Aug 23, 2007 | InFocus ScreenPlay 4805 Multimedia...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Center of my T.V. is black.
Turn off all closed captioning in menu and change it from text to caption.
Jan 16, 2007 | Hitachi 51S500 51" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
