Question about RCA OPAL M4001 MP3 Player
Key lock don't know how i did it but now my mp3 opal turns on but says that the key is locked and then it shuts down i have tryed to reset it but that dosn't seem to work any ideas?
  • 1 more comment
  • Anonymous Apr 14, 2008
    I plugged in my rca opal mp3 player still willnot come on even after I've resitted it. Can you help me with this problem.
  • stichscout Dec 13, 2008
    help i to am having the same problem
  • Anonymous Dec 20, 2008
    my RCA OPAL M4001 MP3 player says key lock then shuts down. How do I fix this?
I did that but nothing changed, help
Posted on Aug 10, 2008
Okay there is a hold slide on the side of the mp3 player you must have slide it up accidently now slide it down. that is the hold key or loak
Posted on Apr 16, 2008
This is the exact thing to do. Thanks my polishness added to my drunkeness made me slip this swith and freak out too....
Posted on Aug 15, 2007
On the side of the mp3 players is a button that slides up or down to lock the keys slide it to the unlock postion
Posted on Aug 01, 2007
SOURCE:
Keys locked
you go to whereever u got it and ask them
Mar 01, 2010 | RCA OPAL M4001 MP3 Player
(RCA OPAL M4204A) An update was sent via internet, it went to my unit and errased the data (as warned) and the OPAL's program. It will not leave the 'initialize' window. Turning on and off and on...
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Oct 27, 2008 | Audio Players & Recorders
RCA Opal MP3 player stuck on "keys locked"
ThaMp3Doctor
I quote
Oct 07, 2008 | RCA OPAL M4001 MP3 Player
Turning on, "keys locked" message
ON THE SIDE OF YOUR OPAL MP3 PLAYER THERE IS A SLIDER THAT CAN SLIDE UP AND DOWN IT SAYS HOLD. IT MUST BE DOWN. IF IT'S UP THEN IT'S LOCKED.
Sep 28, 2008 | RCA OPAL M4001 MP3 Player
Keys locked.
The user's manual is available from RCA's website - it will show you the location of the lock switch.
Jul 03, 2008 | RCA OPAL M4001 MP3 Player
Mp3 player says key locked system shut down
I had this same problem on another RCA player.. with no instructions manual it was hard to figure out what keys locked meant. Then I noticed a little slider on the side of the player, it has a little icon of a pad lock on it. Once I slid this back, the keys lock problem went away and I was able to listen to my music once again.
My best guess of what keys locked means.. you don't want you mp3 player to turn on when you put it in your pocket with your keys, so you change the slider to be locked, when your sit down and your keys are pressing against your on button, the mp3 player will shut off... as we all have experienced in frustration.. saving your battery.
Perhaps RCA should make this slider bright orange so it pops out and does not blend in so much, or they should put it right next to the on button.
Apr 30, 2008 | RCA OPAL M4001 MP3 Player
Keys locked
On the right side , there is a button that says "hold" . You probably have it on, so slide it down and it should work fine.please post something if this helps.
Mar 08, 2008 | RCA OPAL M4001 MP3 Player
First of all its an rca opal M4002
press the reset button then press play
Oct 09, 2007 | RCA OPAL M4001 MP3 Player
Keys locked on a M4002A RCA opal
On the side there is a switch try pushing tht DOWN and it might help ......... If it doesn't work I am really sorry ! :)
Oct 04, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
570 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
