Question about Ariens Garden
Ariers snowplower Start fluid will start but will not run . 7hp Tecumseh motor .getting gas and oil ok
BLAZZ81
  • 281 Answers
SOURCE: chevy astro van turns over but wont start when
Check to see if the fuel pump is kicking in,
when you turn the key on without starting the van you should hear it kick on for about 2 seconds,
It could be...
A clogged fuel filter...
Blown fuse for the pump..or bad pump relay..
No gas
Bad fuel pump
Posted on Mar 07, 2009
panilling9
  • 284 Answers
SOURCE: 4.5hp Sears/Tecumseh motor starts and dies in 5 - 10 seconds.
metal or plasic float?
Posted on Jun 21, 2009
  • 62 Answers
SOURCE: 8 hp Tecumseh HM80 won't start
plugged carb
Posted on Sep 26, 2009
vincob
  • 718 Answers
SOURCE: i have a tecumseh 8hp on a snapper handlebar
If plug is dry than you are not getting fuel to the plug something is plugged up in the carb clean it thoroughly and make your coil gap is correct. But I would lean more towards the fuel not reaching the plug.
Posted on Jul 18, 2010
SOURCE: Coleman Powermate 5000 with 10 HP Tecumseh engine.
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Posted on Jul 27, 2010
I installed new carb. on my tecumseh 5hp. snow king and it wont start. I have spark and gas is flowing out of carb.
This can be very frustrating and tough on the back and arm.
Always confirm the the fuel tank valve is open and the stop/run switch is in run position
It takes three things to run:
  1. Compression. This is the resistance that you feel as you crank the engine. Some engines have compression release to assist getting the rotation started. You should be able to feel the compression stroke as you rotate, Remove the plug and you can easily tell the deference. If it had, last time used, been running and starting with no problem I would assume that the compression is OK. Gauges are available to check. at lease 120 PSI
  2. Spark. It is near impossible to lose the spark timing on these. It can only be magnitude and presence. If in doubt about the condition of spark plug replace. I usually lay the plug on top of the head with wire attached and observe for the spark. No spark no start.
  3. Confirm that the throttle is in the wide open position. It is possible during the repair the spring or rod has closed the throttle air valve. Air/fuel mixture is always hard to trouble shoot. I use open choke and starter fluid to conform that compression and spark are working. After that I will choke on a cold motor and pull listening for the first fire. At the first fire I would usually half choke and pull to first run. Full choke for many pulls will only flood engine!! If no joy then I would allow engine to vent and go back to start fluid. If it will run on start fluid than either carburetor is messed up or quality of fuel is bad.
If after several tries and fuel is certain to be good remove plug and check for gas. It is possible that the new carb float valve or mixture adjustment screws are messed up.
Jan 10, 2016 | Tecumseh Garden
On a 1973 Ariens Snowblower with a 7hp Tecumseh motor what is the proper way to check oil level? Do you screw the dip stick all the way in or let it sit on top of the oil fill hole?
To check the oil you screw the dip stick as far as it will go. Before you start take the stick out and wipe it off then insert and screw it in to the bottom then take it out and check it.
Jan 26, 2015 | Garden
Craftsman snowblower will not start
Dump out the old gas and put in new.Try a spray of starting fluid into the carb. If it will not fire on the starting fluid there is somthing wrong in the ignition system. Pull out the spark plug and clean it with a wire brush. If it still won't fire the points and condensor need to be replaced.
Dec 21, 2013 | Craftsman Tecumseh Snowblower 7hp...
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
I have a husky 7hp compressor , sometimes when i tries to start the motor buzzes and blows the breaker , but if i advance the pulley it will then start
The start capacitor is bad. Getting near the terminals can give a huge shock. so just get the value off the side and replace it.
Feb 19, 2013 | Campbell Hausfeld Air Tools & Compressors
Have a murrry mower with 12 hp moter put a cut off on gas line some times runs ok then will start flooding if you cut gas line off start engin it will run a second or two then start blowing oil out an
If you have a float style carb I believe the float has become a "sinker". Pull the float bowl off the carb and set aside. pull the float pin and also set aside. carefully remove float and needle, set needle aside. Shake the float near your ear. If you hear sloshing in the float, replace it. No? check needle and seat for wear, or since you're into the carb this far replace them. This info is based on Tecumseh carbs, but B&S or Kohler should be similar. If there are any other questions don't be afraid to ask. There is no such thing as a stupid question.
Jan 29, 2013 | Briggs & Stratton Garden
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Centura 3.8 HP Tecumseh lawnmower not working w/o starting fluid
main jet blocked needs carby service its worth it
May 12, 2010 | THQ The Lawnmower Man
Garden Logo
55 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
