Distorted picture When powered up picture is distorted with horizontal jagged lines over complete screen. Picture improves after runnig for a while but fault is still there.
  • 1 more comment
  • peter355 Jan 31, 2009
    Picture fuzzy. The outline of all characters are jagged and the jagged lines are running up the screen.
    does anyone know if this is design weekness with this model as the same fault happened two years ago.Is there a module which maybe Toshiba have modified since original release?
  • peter355 Feb 01, 2009
    The picture quality is worsening daily.How do I identify which module may be at fault so that I can remove and get it tested ?
    Master:
  • 623 Answers
Do a hard reset, chances are this will take care of it.
HARD RESET: Unplug the power cord for 4 hours; then restart the tv.
If the reset does not cure the problem, I suspect there is a power supply problem. The culprit is likely to be one of the electrolytic capacitors in the power supply which has the purpose of filtering the ripple voltages from the bridge rectifier.
If the capacitor is the culprit, they are not expensive to replace but must be done by a tv tech - unless you are technical and know how to troubleshoot and solder
Posted on Feb 04, 2009
    Scholar:
  • 61 Answers
Remove the wires from the TV. The yellow usually works for the screen and picture. There could be dust or debris in hole or on the male part of the wire. Get an air blower, clean it out. NO WATER!! Put it back it in, with the TV on. Adjust til' no more lines.
  • 19,396 Answers
It looks like a convergence problem, you need to test and eventually replace the convergence ICs.
Here is a general How To: Fixing Convergence problems in RPTV's
Posted on Feb 02, 2009
  • 11,896 Answers
Your TV has a convergence board problem which is very common with these types of TV's even with the other brands. The fix for this is by replacing two identical IC's with part# that starts with STK. For your TV
  • Nate Stansfield
    Nate Stansfield Feb 02, 2009
    the part# is STK392-110 but most technicians including me replace these
    with STK392-150 for higher wattage rating and reliability. And before
    replacing these IC's technicians check small components called
    resistors and pico fuses. They also check for loose or cold solder
    connections.
    Brigadier General:
  • 8,619 Answers
Hi!
Check for the cables at the back of your tuner and your tv. See for the feature of Progressive scan on your tv menu, turn it on and it will lessen the effect or also can completly remove it.
Posted on Jan 31, 2009
  • Rylee Smith
    Rylee Smith Jan 31, 2009
    If it doesn't help then your scaler/deinterlacer inside has gone bad and needs to be replaced.
    Thanks
    Rylee
  • 360 Answers
Adjust the horiz. hold/sync.
    Sergeant:
  • 221 Answers
It needs minor repairs on the board.u will have to check the board with a meter first to identify the faulty junction.
  • 81 Answers
Hello
am not understand what the probleme
but if you have garente you can go at the place who you buy it
because that a technic probleme
Posted on Jan 30, 2009
  • mohamed boyzid
    mohamed boyzid Jan 31, 2009
    hello
    i am sorry but i like the sulotion
    if you have garante you go in the company whish you buying this tv
  • 6,784 Answers
OK, this sounds like the rgb calibration module may be going out. try calibrating your tv. this starts off slow but eventually, it gets worse. you may have to place an order for this part so you can replcae it. its quite easy to get to.
    Top Expert:
  • Televison & ... Master
  • 77,499 Answers
This is caused by the convergence circuit board, it can be repaired if u are very good at electroics repair.
  • yadayada
    yadayada Jan 31, 2009
    this is caused by the convergence circuit board, it can be repaired if u are very good at electroics repair.
    Genius:
  • 2,920 Answers
It soundslike a couple of the ICs have gone bad you might want to call in a repairman to have a look at the set
  • Ronnie Houston Jan 31, 2009
    toahiba is always trying to update or modify so its harder to find the parts you need sometimes to fix the previous models.they havent had any recent recalls on tvs and the models they are coming out with now are even harder to work on than they were 5 years ago.this was why i suggested to you that you have a repairman come out to look at it.people on here arent able to keep up with any of the major updates that each model has come out with and the tv repaimen are required to keep up to date .
    Genius:
  • 1,199 Answers
Capaciters on the main board are bad and will need replaced1
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Oct 14, 2010 | Sony KV-35XBR48 35" TV
When i turn on my tv it starts with a very distorted picture
got the same TV with the same exact problem....what is it??? if u crack it tell me and i'll do the same...
Oct 07, 2009 | Toshiba 50HDX82 50" Rear Projection...
Picture distorted
this a problem with the motherboard. not the lamp.
Feb 05, 2009 | Toshiba 56HM195 56" Projection HDTV
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Sampo PME-42S6 W/red lines runnig through the picture
Try using a DVD player with Progressive Scan, it might work fine. I don't know what the problem can be but that's the only way I can see anything.
Jan 08, 2008 | Televison & Video
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
Jagged horizontal blue lines everywhere
convergance amp ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 10, 2007 | Mitsubishi VS-45609 TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
