Question about Canon PIXMA MP600 all-In-One InkJet Printer
Keeps saying no papper and jamming it wont print help
  • devo32 Jan 30, 2009
    hi thanks but i tried this a million times keeps doing it it takes the papper slowly then chews it then says there is no papper
  • 214 Answers
Hi. I have a pixma too. Try this. Turn off printer, unplug from wall, wait 2 minutes, plug in & turn on. This should do the trick. I have to do it every couple of months. Hope this helps.
Posted on Jan 30, 2009
acdr
  • 1913 Answers
SOURCE: i have a dc 150
there are any paper jam remove those paper also try to change the catridge refix again
Posted on Oct 07, 2008
  • 1584 Answers
SOURCE: error message says paper jam and there is no paper
Pull plug out of wall for 10 min, replug in and retry.
Posted on Dec 03, 2009
pineworks
  • 4041 Answers
SOURCE: i have a canon mp240 and i keeps saying that i
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
  • 1218 Answers
SOURCE: when i have no papper
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Jan 04, 2011
Printer says papper jam but thier is not any paper jam
Be sure that there is a paper jammed inside. You cant just see it.
May 09, 2014 | Lexmark S515 Multifunction Printer
Scx 4632f
hi, your printer papper out senser is damaged or papper out senser liver is damaged please check
Apr 02, 2014 | Samsung Office Equipment & Supplies
It says tacke away papper from huvud fack in swedish. its no papper wher they come if it prints att it shuld. whats the mater it maks mi nervus . cant print enything its stuck one this error message!?...
You have not cleared the entire media path, or you didnot open the door specified by the message to check for jams in this area.Please clear media from the entire path, open the door indicated by theoperator panel message, clear the jam, and close the door and the printer resumesprinting. For further assistance, please contact LexmarkTechnical Support.
Jun 16, 2011 | Lexmark C510 Laser Printer
Incomming fax same page printing contenusly and wasting paper
put machine oil on papper roller let run a few pappers intell it gets worked in then see if paper is sticking if this doesnt work blow it out with air in can there has to be papper jamming the papper side.
Feb 13, 2011 | Ricoh 3310Le Fax Machine, FAX3310Le...
I have a canon mp240 and i keeps saying that i have a papper jam but i have taking out the paper but it still wont print correctly and now it wont let the paper go thru to the ink cartridges
Hello there
Mar 03, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Lexmark E234 Paper jam light wont go off
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 21, 2009 | Lexmark E234 Laser Printer
PRINTER JAM
look for small, small pice off papper in the printer where pappers pass tru
Sep 29, 2008 | Dell 1720dn Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
