Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How do i attach the upolstery attachment? - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Posted on Feb 07, 2009
I have a Braun KS32 Kitchen Machine with several attachments. Two attachments are missing instruction manual/uses: KS 32, Shredder/Slicer Attachment, and KGZ 2 Meat Grinder Attachment. Is it possible...
I have a braun machine KM32 CDN 120 Vac/3A/60h2, No. 4122912 and I was wondering if there is an attachment for a pasta maker for this machine. If there is how much is it and can I get one in Saskatoon SK Canada?
Nov 29, 2010 | Vacuums
How do i release. the hose to attach the attachments?
Near the carpet attachment, on the lefthand side of the hose, there should be a release mechanism that you simply push in with your foot while pulling on the hose/wand. Once the carpet attachment is removed, you can connect the other attachments. Push the release toward the hose.
Nov 04, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
ATTACH UPHOLSTERY ATTACHMENT
What is the Model Number of the Steam Vac?
It should be something like F58XX-XXX
Sep 29, 2009 | Vacuums
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to attach the upholstry cleaners
Easliy download the manual at Hoover.com.
The hose attached in the front of the unit on the clear front panel. Lift up the center cap and attached the hose. Then attache the supply hose to the side of steam vac for your solution.
May 25, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Putting on the attachments for the kirby g4
Well... some attachments you may end up not using at all... some of them are very handy...
I have online manual for attachments HERE
Good Luck
Mar 02, 2009 | Kirby G4 Bagged Upright Vacuum
I have the same problem with intermitant power, however, it does not make sense that the problem is in the upper powerhead (which is what a repair guy told me) because-- when I use the other attachements...
You can test the auxiliary plug to the roller/beater attachment with a volt meter if you know how and take precautions. Check for 115-120 volts at the beater/roller attachment plug. If voltage is there and the beater/roller doesn't run, the problem is with the attachment. If not, then the problem is in the power switch or somewhere else that feeds power to the lower attachment.
Feb 23, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
BISSELL PROHEAT SHAMPOOER WITH SCOTCHGUARD ATTACHMENT
If one attachment works ok, but another doesn't, then there must be a problem with the attachment and will have to be replaced.
Nov 25, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
158 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
