Question about Samsung RS2630WW Side by Side Refrigerator
Ice turning into a solid block in freezer. Samsung Refigerator
Samsung, model RS2533SW /XAA The ice is turning into a block in the freezer. The freezer is working, and not defrosting. Everything else is fine. It appears as if the ice cubes are being dumped before they are fully frozen. The water is not overflowing out of the cube container because the ice and water levels are always noermal.
Thanks for any help on this
  • 700 Answers
When you look into the freezer where the ice maker is do you see something hanging underneith the ice maker? if you doi that is the sensor. If not contact me and I will walk you thru the steps to correct the problem.
Posted on Feb 01, 2009
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
Samsung Refrigerator MODEL RF263AEBP/XAA. Freezer is Cold But Refrigerator is Warm
remove back cover in the freezer and check the evaporator fan motor. Also see ice patern. Possible defrost problem
Aug 24, 2014 | Samsung RF265AA Bottom Freezer French Door...
SAMSUNG MODEL RS2533SW/CUR ICEMAKER MAKING ICE BUT NOT DUMPING
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
My freezer keeps icing over into a solid block, and it stops working
possibly the drain is plugged or the drain line, which runs down from freezer on back of unit, to the drip pan underneath. U can blow it out with compressed air
May 29, 2012 | Maytag Refrigerators
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
Apr 22, 2010 | Refrigerators
Hey, Your defrost thermostat or defrost heater may need to be replaced. The frost should be removed every 8 hours automatically. The ice is not freezing all the way into cubes because the temp. is too warm in the freezer to make ice.
The wire may just be a ground wire BUT it may have electrical current going in it.
This is dangerous and need to be repaired. Hope this helps.
May 06, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
514 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
