Question about Whirlpool GH7208XR Convection / Microwave Oven
Whirlpool model MH7100XYQ microwave, exhaust fan
Exhaust fan has stopped working. all other features work great. Help with any suggestions.
  • 318 Answers
Sometimes the control board will short out and not let the fan or cook top light work.
if you want to try and remove the control board, look on the back of the board for any burnt off tracers. those are the wiring connections on the board that move power from a wire to a relay.
it is usually easy to see the burnt out piece, and if you can solder a new wire across where the burnt out part is, then it should work ok again.
if you cant solder, then a new control board will cost about 125-150 bucks.
Posted on Jan 30, 2009
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
Jun 22, 2015 | Samsung Microwave Ovens
The vent fan is not working but micro is. Replaced charcoal filter & reset still not working.
follow this steps and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#12#ixzz2gURd1VtM
Sep 30, 2013 | Whirlpool WMH2175XVB Microwave Oven
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
The fan will not stop running,says locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it's still running, is it the hood vent exhaust fan (which you can normally turn on and off manually) or the internal cooling fan (which normally comes on automatically whenever you microwave)?
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2929351-fan_will_not_stop_running_says_locked
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | Whirlpool Microwave Ovens
Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 13, 2008 | Microwave Ovens
Whirlpool Microwave No longer Heating Food
The most common cause of that is a shorted or blown high voltage rectifier diode.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
More info here: http://www.gallawa.com/microtech/diode.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Whirlpool MH7135XE Microwave Oven
Inner 'glass' of door
The inner glass can and should be replaced. It protects the metal mesh screen from getting dirty, which can cause it to be damaged and allow microwave leakage. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Sep 17, 2007 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
584 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
