Question about Nokia 6300 Cellular Phone
Screen doesnt light up
My phone is still working ok but the screen wont light up since my son messed with it! I want to try and restore it to the factory settings but dont know how to. Havent got a code. Will this help?
  • 26 Answers
Actually, it sounds like your son may have damaged the ribbon cable that connects to the flip piece of your phone. Its a longshot, but its happened to me (daughter)
Posted on Jan 30, 2009
My sons 10" Zeepad has a flipped/ mirrored screen, even the touch screen buttons are reversed.how do I get the settings back? I've restored several times..& it won't reset or restore to factory..?
Try pressing "Ctrl" and "Alt" at the same time. Whilst holding these 2 buttons down also press one of the arrow buttons. The arrow down flips the screen upside down, the up flips it right way up, the right to the right and left to the left. This is a great trick to mess somebody's screen without doing any damage. If they don't know about it, it really messes with them......as you my well have found out. Good luck.
Sep 10, 2015 | Audio Players & Recorders
Me and my friend are takig turns using my other friends ipod and my friend forgot the passcode and tried to much, and nw it says connect to itunes. when we do it doesnt work and so we tried everything, we...
With the phone UN-PLUGED and powered OFF. Hold the home button and plug into a computer using I-tunes. Continue to hold till the restore screen starts on the computer. You will restore the device to factory and loose everything but it will be useable.
Feb 24, 2011 | Apple iPod touch
My samsung sgh-a877 wont calibrate correctly. The touch screen is messed up. I tried several hard restores, nothing will fix this, supposedly. Calibrated several times, as well. It keeps getting worse. ...
sir i tried and tested it in chinaphone ,lets see if it also works in samsung...press power key and # , if not works insert a working sim and send message to that sim ...if the phone received the message it will automatically calibrated thanks and goodluck
Jun 12, 2010 | Samsung SGH-A877 Impression Cell Phone
Hi I have a nokia 6280 that ny son had be using now i got a unlock code etc from Vodafone the other day so i could use it with my simm card as its an optus one, everything is working ok until i want to add...
Hi! Try to format your phone. Go to Menu- Settings - Restore factory settings- Restore all. If your asked for a code try 12345 or 00000 (if this does not work ask your son, maybe he changed that code). If the phone still does not work after this, it may have a problem with the software and need reimplementation, so you need to go to a service to do this.
Dec 04, 2009 | Nokia 6280 Cellular Phone
Cant use keypad on games!!!!
heres what u do, if ur ok,star, 0, or # buttons dont work open your phone and hold the ok button. while holding the ok button close your phone and let the ok button go.. it should do the trick. if not the first time try it again...
Jul 24, 2009 | LG enV VX9900 Cellular Phone
System wont boot
As much as we would love to see you beat your system this is a common issue with systems laying around commonly its a card inside that pops off the motherboard. Just coming off the width of a human hair is enought to disable the entire system. It protects against accidental shorts due to mess ups techs can do when they build systems. Just pop the side off touch mental to kill any static in you and then remove all cards you see in the system i know this sounds confusing but i can walk thu it by phone much better. 3868487115
Apr 01, 2009 | Dell Dimension 8250 PC Desktop
Insignia D300a
First try a simple windows pc restore, go to the start menu, then to help and restore center and click on "restore my computer to an earlier date" then choose a date before your son mucked up your PC. Boot in safe mode if it wont boot (repeatedly tap f8 during boot)
If this doesnt work ring your pc manufacturer and they will send you restore disks.
If you have built the PC yourself ring microsoft and give them you windows product key and they will send you a new copy of windows.
Mar 05, 2009 | Computers & Internet
Ipod 1st generation doesnt show up on itunes & wont restore
ziphone is notorious for permanently bricking iphones...if you interrupted it when it was messing with your baseband you're screwed. As far as the nano goes, did you try disk mode yet?
plug in your ipod, flick the hold switch on then off again, then hole menu and select for 6 seconds till apple logo appears, then immediately hold down select and play/pause. this should bring up a checkmark with ok to disconnect. from there, you should be able to either immediately see it in itunes or format it with HFS+ or FAT32 depending on your OS. Good Luck...
Aug 07, 2008 | Apple iPod touch
Need to know how to what's wrong & how to fix
for ur sons DS try to move it around to find a signal. for ur daughter's, trying doing the same first and if it doesnt work, buy a new charger if the new one doesnt work its the DS
Nov 02, 2007 | Nintendo DS Lite Console
Son ericsson wont switch on
G'day guys, whats most likely happened is that the there is something wrong with the erom or phone software, I've actually encountered this problem before and fixed it. I listed a set of instructions on my google page: http://trogg07.googlepages.com/
use the search engine to look for the necessary software.
rate me if this has helped you out :).
Nov 02, 2007 | Sony Ericsson K800i Cellular Phone
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
