Question about Microsoft Office Professional 2007 Full Version for PC
MS Word 2007 will only open in SAFE mode
When I try to open word, it give me the warning: "Word failed to start correctly last time. Starting Word in safe mode will help you correct or isolate a startup problem in order to successfully start the program..." Then asks if I want to start in Safe mode.
I can start a new document in Safe mode, but if I try to retrieve an existing document, the cursor just spins. I noticed that this happens with Publisher as well. Excel seems to be fine.
I have uninstalled/reinstalled MS Office, but nothing's changed. I've read about the normaldot.... files, but am not sure if this is related or how to go about resolving my problem. Thank you for your help.
  • 2 more comments
  • tdepedro Feb 03, 2009
    No, this did not work for me. Thank you anyway.
    No, nothing found even in the hidden files. Problem still exists. Do I have a virus? Thanks again.
  • tdepedro Feb 04, 2009
    I uninstalled/installed Mircosoft Office again and applied the update you linked, but nothing has changed. Arghh!
    Thanks again for you help!
  • wqqafnd Feb 07, 2009
    Windows Vista Ultimate + SP1
    AMD Athlon 64 X2 Dual Core Processor 4400+ 2.30GHz
    MS Office Professional Plus 2007 + SP1
    It seems only Word fails while PowerPoint and Excel works fine.
    Thanks for any suggestion!
I had the same problem. Ran the updater, reinstalled, and still had the problem. Searching for and deleting Normal.dot fixed it immediately. YAAAAAAAAY!
Posted on Feb 10, 2009
  • 258 Answers
Try opening internet explorer --> Tools --> Windows updates
If you cannot see tools in the menu bar at the top tap the <ALT> key once
Once into updates choose custom and apply all updates for Office or Word 2007
If you still get the error try opening word, click Help --> Detect and repair (it may ask you to put in your Office/Word CD)
Posted on Feb 02, 2009
  • 1 more comment
  • Peter Conway Feb 03, 2009
    Ok, next step is to delete the normal.dot file or at least rename it.
    1. Close all word/office software windows
    2. Open windows Explorer
    3. Search all files including hidden for Normal.dot
    4. right click on any found and rename to old_normal.txt
    (the reason for changing the file type is all .dot files are run at startup)
    5. this may give a warning so click yes to rename
    6. Open word and see if the problem is resolved
    HPC
  • Peter Conway Feb 04, 2009
    ok, it must be something else.
    I would suggest running spybot search and destroy
    In the run box type sfc /scannow
    to check all windows files, may require your windows disk
    Also please post:-
    Which Windows?
    Make and model of PC plus the chip
    Start --> Control Panel --> system
    If you want to use premium chat, I know it costs but it may be quicker to solve!!
How to restore all powerpoint 2010 files?
Hii..
There are different methods available to recover corrupted PPT.
Method 1:
Move the PowerPoint to different location : this is first and very useful troubleshooting method to repair PPT problems . Copy presentation and paste it on other computer hard.
Method 2: Open presentation in MS word document:
If you have tried above method, but still facing same problem then try to open corrupt PowerPoint in MS Word. Follow this below steps:
• Open MS Word.
• Click on Open button of File menu.
• Select Files of type box and navigate to your corrupt file, Open it.
Method 3: Use Safe Mode
To see your presentation in safe mode, first of all you will have to run PowerPoint in safe mode. Follow these steps to do it...
• Click on Start button.
• Select Run & type "C:\Program Files\Microsoft Office\your MS office version\Powerpnt.exe" /safe".
• Now press OK button.
• Restart your system, during restart press & hold F8 button to start window in safe mode.
• Open & see your presentation.
Method 4: Try Third part repair Tool: If all above method fail to fix corrupted presentation then you can try third party PowerPoint Restore Toolbox
http://www.powerpoint.restoretools.com/
Feb 02, 2015 | Microsoft PowerPoint for PC
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
My ASUS UX50 laptop has problems starting windows. Every time I turn it on it says "windows failed to start" and gives me the option of choosing safe mode, safe mode w/ command prompt, last known...
Seems like there are Operating System files that got corrupted. Try to boot the PC into the Windows OS setup disk. Run the setup, choose the currently installed Operating System then select Repair. For more details please check this link - click here
Hope this help. Goodluck!
Mar 28, 2011 | ASUS UX50VRMSX05 Notebook
STOP: 0x0000000024 that is the error message I am receiving and can't seem to get past the screen that gives you the option to start in safe mode
if this happens when starting to boot to Windows, try last known-good config. When system is restarting, tap F8 a couple of times to get to the Advanced Options menu where Safe Mode is also listed. Select Last Known-Good Configuration if available and press Enter. If this does not work, try selecting Safe Mode. If you can get to Safe Mode, you can try System Restore to a previous restore point available when your system is working properly. If none of the things work, try Windows repair or reinstall. Make sure to try to backup data if you can before doing any reinstall or repair.
Sep 16, 2010 | Compaq Presario Notebook
My computer froze during shut down, so I turned it off using the power button. When I start it up It gives me the options of starting normally, Last known good configuration, safe mode safe mode with...
Try go into BIOS by hitting the DEL key or F1 or F2 as you start and go to save Cmos config. then reboot.
The other approach is Last known Good config is the best. This can be brought up after presing power button then by tapping F8 till screen apears.. Select Last known Good Config
Nov 08, 2009 | Sony VAIO VGC-RA840G PC Desktop
Laptop would not start up
try starting your comp in safe mode by tapping F8 after pressing the power button.goto - start - all programmes - accessories - system tools - system restore. then select the date when you think your comp was working OK!
Jun 09, 2009 | Dell Inspiron 6000 Notebook
Can't run outlook 2007
Try opening Outlook from run command window
Start > Run > Outlook /safe
If it works fine close outlook
Go to following registry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
HKEY_CURRENT_USER\Software\Microsoft\Office\Outlook\Addins
Delete the addin key from the regitry
Happy computing :)
Apr 09, 2009 | Microsoft Office Outlook 2007: Windows
Northgate not booting correctly from HD
If you can't get it to boot from last known config, safe mode, or anything else, you won't get it to boot from CD. Sounds to me as if the HD has failed.
Mar 20, 2008 | Northgate STAC2217L (Bundle) PC Desktop
Fail to start up
The error in the self test is probably just a warning that your battery is near the end of its life and is NOT related to your startup problem.
The startup problem is likely a failing hard drive. If there is data on your computer you want to save, STOP testing it and take it to someone that can do hard drive recovery.
you could also buy a USB hard drive enclosure (about $20-$30 at most stores.) if you have another computer to plug the drive into.
Dec 25, 2007 | Dell Latitude C610 Notebook
Computer shut down ..wont restart
what has happened is your hard drive as failed and that is why it shut down and then gave the unmountable boot volume. You could try repairing windows using your XP cd but it's a new hard drive i recon.
Oct 05, 2007 | Compaq Presario M2000 Notebook
Microsoft Office Professional 2007 Full Version for PC Logo
5,142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
