This sounds like an answer to someone's question? You need to click in the MY ANSWER box under the question. It doesn't work adding your ANSWER as a new QUESTION.
Laura: cuando conectas un zebra net a una impresora zebra, se habilitan en el setup las opciones de red, como lo es la IP, GATEWAY, etc, y asi sabras que el zebra net se ha reconocido.
Usually a 7 speaker set up is either a 7.1 or 7.2 system. the .1 and .2 are reffering to subwoofers. this is the normal setup configuration for the speakers.
The 016-783 error message indicates that “Cause – Could
not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the
scans in had previously been deleted, so I had recreated the shared
network folder. What I had neglected to do though was to recreate the
sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup
referenced in the job template I had no more error codes with that
scanning job template.
Click this link- WR-100 Weather/RDS Radio Manual. I got this link from the Manual section of Midland WR-100 Weather/RDS Radio web page on this website.
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
