Question about Kenmore 24 in. 16039 Built-in Dishwasher
I have f11 error code
My range is kenmore 790 source with f11 error code control is locked out model 790 30172400 serial f52105287
  • 15,935 Answers
This is not a known error code.
Please re-check and re-post.
Thanks!!
Posted on Sep 26, 2010
Kenmore Elite 665.1392 / 665.1394 Control Lock Light is on. No other buttons are responsive. Dishwasher won't run.
The control lock should toggle on and off if you press and hold that button (on the right side of the group of buttons) for 3+ seconds. Until the lock is released, the other buttons won't work. If the lock won't release, either the keypad or the control board are not communicating the unlock signal between them. (This could indicate a problem with the wiring, one or both of the two boards.) The parts list for the 665.1392 control panel is available here: http://www.searspartsdirect.com/model-part/66513922k010/0583/0130000/k1203262/00002.html . There may be other sources for the parts.
You'll need to open up the control panel to do any diagnostics. If your dishwasher is still under warranty, contact Sears for a service call.
I hope this helps.
Apr 26, 2016 | Kenmore Dishwashers
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Does anybody know how old a Kenmore dishwasher model# 665.13262k111 might be?
John,
If you go to the included website and go to the bottom and fill out the form, they should be able to tell you how old. Several manufacturers recycle their model and serial numbers, so you might have a range of dates to choose from. You will need your model and serial number to get the info.
Appliance411 Service How old is my appliance Age finder date of...
Jun 11, 2015 | Kenmore Dishwashers
I have an EE code displaying on the front
Thank you for your post, friend!
I understand that your Frigidaire dishwasher is showing a "EE" error code. However, it appears "EE" is an invalid error code. May I have you model number please? Typically you can locate your serial tag (which lists your model number) on the inside of your dishwasher on the right hand wall. With this information I can better assist you with pinpointing the issue.
In the meantime, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes. -Matt
Sep 03, 2014 | Frigidaire Dishwashers
I have my kitchen wiht a padlock on the display I am pressing the Oven light button press for a moment and comes out on the screen F11 ERROR and all the kitchen is locked I cant Use it.....please need help...
Hello Ana, thank you for allowing me to assist you!
If you are receiving an error code E11, the unit may have a shorted keypad. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to reach out to an experienced appliance repair to assist further since more than likely the EOC (electronic oven control) will need replacing.
Sep 11, 2013 | Frigidaire Professional Series 24 in....
Lock light flash
Please check the link below but take estimate if more spares are needed so as to compare the cost of a new washer.
click on:
http://www.espares.co.uk/search/dishwashers/p/1083
Dec 06, 2011 | Dishwashers
Error code C1 PO......
Hello. Your model dishwasher has a recall on it. There is a potential problem with the control board. Call Bosch at (800)856-9226 to find out if your unit needs to have a new control board installed and re-programmed. This only covers the replacement of the control board--any other problem will be covered by the customer. You will need the model and serial number. Next, regarding your model's problem...this was gotten from another tech site(I'm a member of quite a few, lol)
"Sounds like the unit is stuck in the control coding mode. C1 is the proper coding for your model so you just need to lock it in.
To enter coding mode, press and hold the second, third, fourth and fifth buttons to the right of the display simultaneously, then turn the dishwasher on using the On/Off switch. The associated leds will be blinking to confirm coding mode.
Release all buttons to view control coding. To change coding, press the second button to scroll through codes C0 - C9. C1 is the correct code for your unit.
Turn the dishwasher off to save control coding and exit coding mode." I hope this helps you! Let me know if you need further assistance!---Thanks!
Jan 09, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Will not stop washing
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%%%%
Apr 14, 2010 | Maytag MDB5100 Dishwasher
Dishwasher won't start, turns on but no display
1: Defective door lock switch
2: Defective electronic control board.
Get model and serial number of machine, enter model number on search engine and seek same like conditions. You should find solution to problem, or place model number here for me to correctly tell what is wrong.
Oct 01, 2009 | Dishwashers
Kenmore 24 in. 16039 Built-in Dishwasher Logo
977 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
