Question about Creative Labs WebCam Live!
Says camera not plugged in
I have a custom version of xp pro and installed the correct driver, the webcam centre says the camera is not plugged even though it is. I have tried various usb ports but all have the same problem. the camera definatly works as i have installed it the same driver on a different computer and found that the camera works properly
any help would be much appreciated
  • 1 more comment
  • stu_2kay6_mu Jan 30, 2009
    hi thanks for the reply :), i tried reinstalling the driver and downloading it from another site but still have the same problem. I recently built my computer and was wondering if it could be related to that in anyway because the camera does work on the two other computer i have it set up on. Now when i plug the camera in even when the driver has been installed it gives ma a found new hardware pop up and when i open creative webcam center it says "the creative camera is not available, it may be in use by another resource@ but nothing i have installed on my computer uses it. I thought the problem might have been because i had a custom version of xp installed so i put a legit copy on and still have the same problem. i reely have no idea what to do :(
    thanks for the help, much appreciated
  • stu_2kay6_mu Feb 01, 2009
    tried this severall times but still no result :( thanks for the help anyway
    thanks will try my best :) thanks for the help much appreciated :)
    President:
  • 8,637 Answers
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 30, 2009
  • Weldon Dube'
    Weldon Dube' Jan 31, 2009
    Do not plug in the Camera until the software that is being installed asks you to plug in the USB port. That's been the problem with 90% of the cameras not working. They are not meant to be a Plug and Play hardware. Give it another try using the method I outlined above. Hope this helps. Bud
  • Weldon Dube'
    Weldon Dube' Feb 01, 2009
    If you plug in the camera and it says found new hardware you didn't follow the directions or it just didn't load right. try disconnecting the camera from the USB port and when it asks you to plug it in do so.
    Also don't unplug the camera after you have installed it because it could cause a driver to be corrupt.
    I have had good luck in repairing computers with the same problem you have.
    Good luck and don't give up as you will find the answer.
Wound up reformatting the hard drive and installed Windows XP Pro 64-bit. But am missing correct drivers for the modem. It does not even show up in device manager
Hi activebiz,
I see you re-installed Windows on the machine with Win XP Pro 64bit but you are having issue with the driver as mentioned.
If I may ask before you installed win XP 64bit did you have win XP 32bit?
If so then try downloading a driver for a 64bit version to make the Modem driver work, having an Incorrect version of the driver will really not show up in device manager, and make sure the driver you are downloading is the correct driver.
You did not mentioned the Brand of the Machine or Motherboard that you have and the modem that you need a driver for is that a built in Modem on the Motherboard or is that a modem external provided by your Internet Provider.
Jul 17, 2011 | Computers & Internet
When installing webcam software (Pro 9000) the setup does not recognise my IE and aborts the setup. Have IE7 working. Thanks.
Upgrade to Internet Explorer 8 and then try installing again. You can install the newer version by running windows update (browsing to update.microsoft.com with Internet Explorer). It may be an optional update, so be sure to do a "Custom" update and manually select the Internet Explorer 8 Install.
Jul 10, 2010 | Logitech QuickCam Pro 9000 Web Cam
During the installation process for a Logitech Pro 9000 webcam, I receive an error message 1406"could not write value ImagePath to key SYSTEMCurrentControlSetServicesLVPr2Mon. Verify that you have...
1st You download Webcam Driver.
my camera installation After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Logitech Camera Drivers for Windows XP Vista Windows 7
Jun 15, 2010 | Logitech QuickCam Pro 9000 Web Cam
QuickCam Pro 9000 Web Cam: I plug in my Logitech Quickcam Pro 9000 and it wil...
It is possible your webcam is either disabled or the driver is corrupted. Try reloading the webcam software driver, reboot, and then try the free webcam test tool to check if it is working properly.
May 06, 2010 | Logitech QuickCam Pro 9000 Web Cam
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
A. Skype Setup:
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 20, 2009 | Creative Labs Live! Cam Notebook Pro...
Skype 4.1.0.179 restarts pc when using camera, is this version not compatable with windows xp?
HI,
Your camera is 100% compatible with Windows Xp.
Please uninstall your webcam first and then skype.After that reinstall webcam and then the skype.
This should fix the issue.
Let me know the result.
Thank you for using fixya.
Nov 15, 2009 | Logitech QuickCam Pro 9000 Web Cam
The Intel CS430 worked on XP, but wont work on Windows 7
The final version of Windows 7 has not been released yet, you most likely have the RC copy of Windows 7 (ie Release Candidate - final beta version just before official release) the RC is available to anyone to download and test.
The problem is that not all device drivers are avaiable and if you cannot get a Windows 7 version from the manufacturer's WEB site at this stage, you have to wait until it is available.
Aug 26, 2009 | Intel Pro PC Camera CS430 Webcam
Creative Labs WebCam Live! Logo
59 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
