Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quite Partner 1 - soap dispenser does not open during
Cycle. Any suggestions?
  • Anonymous Jan 30, 2009
    I have the exact same problem.
    Resulting, of course, in the dishes still be dirty.
I ran it through a couple of different cycles, when that didn't work I closed & opened it several times then rerun the cycle. It opened on its own. I can only assume it had some kind of build-up.
Posted on Jan 30, 2009
I have a quiet partner ii the soap dispenser door will not stay shut, how cab I fix it?
I have the same dishwasher, and have a problem with it shutting when soap cakes up on it. Have you tried scraping the latch door area? Once I cleaned out all the scale it shut better and when I close it, I push gently on the door and help the latch shut. It still opens fine during the cycle and the soap is gone.
Oct 11, 2015 | Whirlpool Dishwashers
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Du920pfgz2
These dispensers fail quite easily, it is a simple job to replace the dispenser.
Mar 11, 2012 | Whirlpool Dishwashers
Soap dispenser will not open during cycle
I have the same dishwasher, have for about 2 years. It took me about a month to figure this out... But, you cannot run it with the flatware rack hanging on the bottom dish rack, you have to move it to hang on the door and you cannot have anything in the compartment under the soap dispenser that is tall enough to block it from opening. Annoying design for sure!
May 12, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Soap dispenser door does not open during wash cycle. it can be opened with the manual release.
close the soap door and put into diagnostics. most models you can do so by pushing heated dry-normal-heated dry-normal. let it do its test and if the soap door opens during the test cycle, most likely the soap door assembly needs to be changed.
Nov 17, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher DU840SWP. soap dispenser not opening during cycle
Does the washer heat the water during the hot cycle. If it does, your soap dispenser module in the door is faulty. To install, you need to pull power plug out first,then sit on a chair in front of the door and then open the door towards yourself. Once open unscrew those screws along the perimeter of the door to enable you to remove outer panel. Once off, you can view how to remove soap dispenser. If water does not get hot, check the heater element and/or the reset (over temperature switch). Note, top rotator must move freely as well to allow hot water dispersion which on some occasions activates the soap dish. On other occasions it uses a solenoid switch.
Oct 03, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Main Detergent Dispenser does not open during cycle
check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
91 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
