Question about Ice Tech A690 2.1 Speakers
Tiny faint sound and no bass
Tried reversing input
L and R, not much there. I suspect a short as develloped in the wire comming out of 1/8 plug wich goes in the laptop. There was a bad 90 degree bend. Humming sound comming out of the woofer section, even if I unplug both inputs. I opennned the sub to look at the board, no sign of broken wire and no funny burned smell, everything on the board seemmed ok. Could it be the transfo (double output 11 V. and 2 V. ) ? didn't have my meeter close by.
  • Anonymous Feb 17, 2009
    i have no bass and faint sound
I just connected two sets of 901'a to Sansui G901 receiver. The sound is TINNY no bass at all. I've tried different connections and nothing seems to work. I've used two different EQ from bosse series
Either there is NO bass on the recordings (if you listen to it with headphones does it have bass?) ...OR...you've wired them out of phase. Connect only one(1) Bose 901's to just one side. Is there bass? Then connect the other side. IS there bass? If not reverse the phase (+ /- connections) and see if the bass comes back. Once that is done and there is BASS, then add the 3rd and then the 4th speaker. .Are you sure your Sansui can handle a lower than 4 ohm load???
Jun 19, 2014 | Audio Players & Recorders
MARSHALL FOOTSWITCH FOR DSL100 TROUBLES
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
Sep 27, 2017 | Music
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here: http://el34world.com/charts/Schematics/files/peavey/peavey_mark_3_bass_with_pa.pdf
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
My bass drum stopped working. The module wont pick up any signal and ive tried everything short of replacing it. Not sure if its the wiring the module or the drum sensor itself.. Everything else works just...
Verify the module by connecting a different pad to the bass drum and see if you can trigger the bass drum sound. This would test the module. Now connect the bass to a different input and see if it will trigger that input. SOME of the triggers have a very small potentiometer in them. I have seen vibration break this pot loose rendering the unit inoperative. Also some people have pushed a screwdriver into the pot too hard and broken it off. Once you know it is the bass trigger, open the unit and look for damage. The sensor is usually a piezo disk. These can break away from their attachment. Reattach with contact cement after cleaning the residue.
Apr 14, 2011 | Alesis DM6 Performance Electronic Drumset...
My Bugera 1960 stopped working in the middle of a rehearsal. I was playing at about level 3/4 in the 1st input of the 2nd channel. The amp was connected to a Marshall 4x10 bass cabinet. The connection of...
Wiring harness connector to the power tube section is fried. A common problem with all bugera amps and many other companies also. A cheap fix. You can order the part you need from newark.com or call 1-800-4newark the part number is sku#85c0290 mfr#09-91-0500
Nov 25, 2010 | Behringer Bugera 1960 Classic 150-Watt...
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
There is power to the unit. But we can not get any sound. the remote works. tried mute nothing.please help
Make sure that your speakers are plugged in correctly and wires aren't shorting out. also try plugging your equipment into another input on the unit. Make sure the any switches on the Bass unit (subwoofer/Amp) are switched on.
Good Luck!
Dec 27, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Fender bass guitar shorting out
Inspect the wires leading to the 1/4" jack on the bass. Try moving them to see if you can figure out which wire is the culprit. Check for any bad solder joints on the pots inside the guitar.
Chances are the jack has been twisted and damaged a wire and/or a solder joint.
Jun 16, 2009 | Fender Music
S/PDIF not working
Hey hoof
My only experience with faint sounds is when ground wires in the particular circuitry are not property connected. That means tracking the wires from the one end to the other if you can get to them. If they are not embended in a casing or housing I would change them.
Also, try changing the RCA plugs; even their connection can cause the sound shorting if there is a short.
Well....hoof... well,,,,good luck buddy.
Dec 31, 2007 | M-Audio Delta 1010 Sound Card
Ice Tech A690 2.1 Speakers Logo
194 people viewed this question
Top Ice Tech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ice Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
