Home | GE | WPXH214A Front Load Washer | Front loader making lou...
GE WPXH214A Front Load Washer
Problem for GE WPXH214A Front Load Washer
Front loader making loud noise with spin cycle
By wayne pa on Jan 29, 2009
can someone please help me. My GE washer is making a loud bang while in the spin cycle. I took off the back. The belt is fine. I took off the wheel which the belt goes around, which is attached to the plasic drum which surrounds the steel drum. I thought I could see inside the plastic drum because the noise seems to be coming from inside there but I can not see in. Its like something is loose inside the plastic drum.. does anyone have any suggestions. Its only 3 1/2 years old, It may be the rear ball bearings, is this a lost cause or can I fix it. I had the same banging problem, late in the spin cycle. I called a repairman who said it was in fact the rear bearing assembly, and that it costs more to repair than getting a new machine would.
Best Solution
posted on Jan 30, 2009
Helpful)
jetfixr
Rank: Guru
Rating: 88%, 42 votes
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 23, 2009
Not Rated)
harry000
Rank: Guru
Rating: 92%, 13 votes
i have the same problem as urs. i open the whole drum myself and replaced the rear bearing. but the actual problem is the bearing housing is loose in plastic drum. so only drum needs to be replaced.
Was this helpful?
Yes
No
Popular Solutions for GE WPXH214A Front Load Washer
Questions and Unsolved Problems for GE WPXH214A Front Load Washer
Do you recommend GE WPXH214A Front Load Washer?
Answer
Answer
what is the drum size of the ge wpxh214aoww? whats the cubic ft of the drum?
Answer
Washer drains and spins but not high speed and clothes are very wet
Answer
washer is noisy and now grease appears to be getting on clothes
Answer
I have a w10117769a and the I have clothes in the washer that completed it's cycle of cleaning and... (More)
Answer
fills up with some water, no spin, moves the control knob thru the cycles extremely fast.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WPXH214A Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
