Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
After an hour or so the screen goes black
Had the set almost 3 years. After 1-2 hours the screen goes black. Something must heat up inside. Should the power supply go bad this soon? Maybe we do need a class action law suit. What does AKAI say about this problem?
  • 7 more comments
  • erlinda Nov 20, 2007
    akai pdp4298 edtv 42 inches,my problem i get a black vertical line in the center,its 21/2 years old tv..........any solutions please email rrs134@sbcglobal.net
  • Anonymous Dec 18, 2007
    I have the same problem- It goes black- I turn it off then back on and its ok? What needs to be replaced?
    thanks
  • stormlover
    stormlover Dec 10, 2008
    i need the universal remote code for the pdp4298 akai plasma tv, any ideas?
  • ultrab20 Dec 13, 2008
    same problem here
  • Anonymous Jan 05, 2009
    gets hot, picture shaky/distorted. Turn it off and it is better, but always happens again.
  • Anonymous Jan 23, 2009
    my tv is about 4 years old and the same thing-after about 2 hours heats up and goes crazy, then shut off for awhile and it is fine? Does anyone know why or how to fix/
  • prospank53 Feb 09, 2009
    I own an AKAI PDP4294, its 5 years old, and I just experienced the same problem. While watching the TV, the screen went black, audio still works. I shut the unit off and unplugged the power supply. After setting all night, i plugged it back in, and still no picture, but do have audio. Whats the problem? Is it something that a technician can fix?
  • Anonymous Feb 19, 2009
    same problem
  • scottr57 Feb 23, 2009
    ya i get a black box
    Problem Solver:
  • 7 Answers
I would like to know how many people have this problem too,my akai just went out the other day too, just researching
Posted on Sep 26, 2007
Using AV button can select HDMI 1, but after a period of time minutes to hours , screen goes black. This can happen 20+ times in an hour.
perhaps a service call at a tv shop can fix your problem . unless your storage was super clean and dry the unit might have corrosion in it .
Jan 07, 2016 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Samsung TV , black screen
Check for the timer settings if possible reset to default......
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Vertical band of green pixels 1-2" wide when monitor heats up
Sounds like you have some pixals going bad.
It could be heat related check to see if its under warrantee. Most screens have a 3 year on them.
Not sure about Dells.
Aug 21, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Picture just disappears...
This is a problem that a repair shop must fix. One or two circuit boards must be replaced. Also several electrical connections must be resoldered because they have become loose.
I had the same condition happen to my set. My cost to fix the set amounted to about 350.00. I wish you luck.
Jerry
Aug 18, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Instructions for Sunbeam clock model # 882-495
Move the second button from the left to set, enter the time in 24 hour format via the HH and MM buttons, then move the button to start. The far left switch, on/auto.off is for the chime. Set to on for 24 hour alarms, set to auto for no chime from 11pm til 6am, set to off, to turn it off.
Mar 29, 2008 | Office Equipment & Supplies
LG Studioworks 700E
It sounds like one of the capacitators inside the monitor is malfunctioning, these little things store a certain amount of necessary power and then discharge it when it is needed.  If it is malfunctioning, it could explain why it takes so long to charge, and why when you hit it, it suddenly comes on.
Jan 09, 2008 | Computers & Internet
Samsung SyncMaster 940MW screen problem
from what it sounds like Tom is that you have a heating problem. As soon as it warms up your monitor goes black. First I would Shut it down for a couple of hours. Unhook the power cord and let it completely cool down. Some monitors have a temperature breaker. When temp reaches a point higher than the set breaker it will shut off or power down. After I would say 2-3 hrs of cooling power it up and see what happens. If after a certian amount of time it does it again you have a over heat problem. If that happens again go to your favorite search engine and enter syncmaster 940mw support. Goto the manufactures web site and find your model. You may be able to find a solution to the over heat there. There is also a possibility there was a recall on that particular model for a overheat problem.
Sep 19, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Zenith Advanced System 3 not working
your tv is in EYE PROTECTION MODE... NO JOKING... You might have damaged capacitors inside near the tv CPU and in the main power supply. Pleasecontact a good service tech for repair Patrick
Aug 27, 2007 | Televison & Video
The set is almost 10 years old and has always worked perfect until today. . .
It soulds as of your solder joints are getting old and starting to crack. If the screen goes completely black then I would resolder all the major solder joints on the main PC board, and if you mean that the screen goes to all snow (as if the cable went out) then I would also pull the tuner and resolder the joints inside it too. If you do not have experience soldering on small PC boards then allow a qualified tech to handle it for you. The fact that it works sometimes means that all major components are fine and the repair shouldnt cost too much.
Jul 13, 2007 | Toshiba CF27H50 TV
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
117 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
