Question about Logitech Cordless Mouse
Dropped a little water under my mouse
Dried it out. new batteries. up and down wheel works but it must have interfered with the optic tracker. any suggestions? would just throw it away but its an expensive one
  • 3 more comments
  • peter581 Jan 30, 2009
    thanks so much for extensive advice. it was a little pool on the desk. i tried to pull it apart but could only find two screws and the rest didnt want to move. anyway, like you say, probably better to buy another one and keep the drinks off the desk in future. will try drying it out again although i left it for a half hour under a pretty warm light with no results,. but thanks again for your help. really appreciate it. peter. www.opalmine.com
    thanks again Dotball. OK i will dry it out more and try to find a way of undoing it. you are a real gem. i appreciate your kind help. Give me your address and i'll throw a little something in the male for your favorite girl. if you have one. [haa] peter
  • Dot Ball
    Dot Ball May 11, 2010
    Peter, because of the conditions of the site I cant accept anything, but here, the best thing you can do is vote on my responses and give me credits for helping you.
    thanks for the offer though something in the 'male' would have been good - in these times my fav does miss out somewhat.
  • Dot Ball
    Peter, a little pool on the desk would lead me to believe the water just pooled up to the laser lens, rather than flowing through the device. Unless you tipped it upside down and then some water would have entered the electronics.
    Peter - half an hour is no where near long enough. I was talking days.
    If you want to have a go at pulling it apart, there are often screws hidden under the slip pads (rubber feet) or under a label - feel, with some pressure, across the label and you may feel, reveal, a hole behind it. push your screw driver so it pierces the label and you may find the screw.
    Please let us know how you go - fixed or discarded.
  • Dot Ball
    OK, this is pretty broad - "a little water", let's be specific.
    A little water on the table, under the mouse is no going to affect it. A little water over the mouse may. Thing is, old-style electronics used to be robust enough that you remove the power, let it dry, power it back up and presto, good to go. Now a days, electronics are fine delicate structures that the slightest bridge, shock or object, including water, can sincerely 'knock out' necessary parts. Considering you have about 2.5-3volts supply in that thing. Some parts of the device are monitoring less than 1volt, fractions of a volt, there looking at humming over .3v and if a sensor supplys .4v then an instruction is carried out. Imagine you looking at a torchlight, if it dims you go left, if it brightens you go right, but if someone standing behind it turns on an array of monsterous spotlights, you squint and turn away and likely wont see that torch when the lights go out - same in electronics. When that water carries 1,2,3v to that little sensor evaluator, it's gone.
    I see 3 options: there is nothing wrong and you have not let it dry sufficiently yet, give it days in dry weather to dry right out; water has carried contaminents (dirt) across the laser emitter or receiver sensor and although working, not effective, clean it with a cotton bud; water has damaged components and is economically irreversible.
    If you have nothing to loose, get a screwdriver and pull it apart and clean sensors. Try not to touch any electronics with anything conductive - including your finger (skin is abundant with acids). Wipe a DRY cotton bud where ever you have doubts about contamination and especially if you can get under the lens for to laser - DO NOT power up and look at the laser, dangerous to you sight.
Thanks for double checking. i am following through on a couple of helpful suggestions. if they don't work, it wont be worth pursuing. the value is not great enough to spend the effort. but thanks for checking, peter www.opalmine.com
Posted on Jan 30, 2009
Scroll wheel stopped working. It feels weird now when i try to scroll it. How do i fix it?
Disconnect the mouse from the computer and turn it upside down. The screws to disassemble the mouse are under the pads on the bottom of the mouse. When you disassemble the mouse, you will find that the scroll wheel axle is gummed up, and the interruptor wheel is probably dirty. Use an old tooth brush and alcohol to clean the scroll wheel components, and let the components dry. You can use glue to re-attach the pads after you have reassembled the mouse.
Sep 05, 2015 | Universal AULA Ogre Soul Professional...
I can't open the casing :S someone spilt sticky drink on the mouse and now the right mouse button is a little gummy and not always responsive .
unplug the mouse and put it into a container filled with distiled water. move the sticky keys up and down until they work smoothly again. take the device out of the water, put it on the heating and let it dry for a few hours/days. i used a blow-dryer to remove the last drops - but watch that the mouse doesn't get too hot. done - good as new...
Dec 14, 2010 | Microsoft SideWinder X5 Mouse
My mouse is messing up when i try to move it den its like a wall blocking it from moveing but if i shake it it can go bye help me asap
I am guessing by the nature of your problem that this is not an optical mouse, but one with a roller ball inside. On the bottom there is a wheel-like door with a hole in the center that holds the ball in. Turn this wheel counter clockwise and remove it. Remove the ball. Carefully with a dry cotton swab clean off the little wheels inside which record the movement of the ball. You may need to stick your finger in there to hold the wheel in place so the cotton swab can knock the gunk off. Take care to not let the gunk drop into the inner workings of the mouse, but if some does, it is not a tragedy, your mouse should start working like normal after the wheels are cleaned.
Nov 02, 2010 | Computers & Internet
I have an HP N3 optical mouse that was doing well until the other day when the middle little scrolling wheel stopped working. Can I fix it or do I have to buy something else? Thank you.
If the entire mouse stopped it probably time for new batteries. If it is just the wheel then it could be a driver issue or setting. If those are ok ie the middle button wasn't disabled somehow or your computer figured it only has a 2 button mouse then its hardware. That means its replacement time. It's possible the switch or the sensor for the wheel are dirty so if you want to you can take it apart and try cleaning.
Aug 11, 2010 | HP Wireless Optical Mouse Sl/Blk With...
Dropped mouse in water
You will need to remove the batteries and let it dry for 48 hours. Having the batteries in the mouse while there is still potentially some water in it will damage the the electronics inside (if they are not already damaged) If after the 48 hour period your mouse still acts funny then you should simply replace it.
Sep 17, 2009 | Computers & Internet
Scroll wheel doesn't work!
There is a design bug in the plastic shaft that connect through the optical encoder. If the wheel just spins and you can't feel "clicks" as it turns, it's very likely that the plastic shaft has worn down enough that it's not actually turning the encoder. The encoder also provides that clicking action; it's a single component. To fix it, take the mouse apart: 4 Phillips #00 screws located under the two black plastic adhesive feet (two under each screw) plus 3 screws (2 #0 Phillips, 1 T6 Torx) located inside the battery cover under the label on the edge with the Microsoft holographic seal. Just peel that edge of the label back to expose the three screws. Torx T6 goes in the middle.
After all 7 screws are removed, the cover removes easily. Locate the mouse wheel and notice the silver optical encoder component through which the mouse wheel shaft enters from the center. If you remove the wheel (gently), you'll see a hexagonal pattern in the shaft. This normally fits the encoder tightly, but wears out over time and use. To repair, take the wheel out and add a drop of superglue to the shaft to that the drop of liquid glue coats only the hexagonal tip all the way around. Do not allow the glue to get on any other part of the shaft or wheel. You don't want to use the glue to actually adhere it to the encoder; you only want to use the glue to add a small amount of thickness to the shaft. After about 30 seconds, use a clean paper towel and gently wick away the remainder and excess glue from the tip of the shaft. This should leave a very thin coat of superglue on the shaft. Allow the shaft to dry completely or use accelerator to speed the curing process. Once dry, attempt to re-insert the wheel into the optical encoder. It should fit tighter now, and still turn freely. If it's too tight, use a sharp knife and GENTLY scrape-off some of the glue on the tip of the gray plastic shaft.
Once you have the wheel shaft reinstalled and you got the clicking action back, you could stop here and re-assemble the mouse. Or, to make the fix last longer, take a toothpick and an extremely small drop of superglue and add it to the outside-facing center of the optical encoder where the shaft is visible. Place the micro drop on the gray shaft, then very carefully work the liquid to the point where it makes contact with ONLY the black collar of the optical encoder. This should glue the gray shaft to the black collar. If you go too far and glue the black collar to the silver casing of the encoder, you may permanently damage the encoder, so be damn careful when applying the glue. After it's dry, the wheel should still turn, click and function normally. Reassemble the mouse and you're done. I've successfully repaired 6 Arc Mice using this method. I used Loctite Low-Bloom Superglue and 712 Accelerator. Good luck.
Sep 09, 2009 | Microsoft ARC Mouse
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Wireless optical 3000 mouse not working
take the NEW mouse and re-install through the control panel option (for win +) or the correct procedure for the OS that you are using. the old one is likely dead. good luck!
Jan 18, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a Microsoft Wireless notebook optical mouse 3000 that my son dropped in the dog's water dish. We have dried it out and put in new batteries, but it won't light up. I tried my other mouse and put new...
the one dropped in the water is probably no good anymore could have corrosion from the water how long did you let it dry.
if you want to use your other mouse first uninstall driver for dog water mouse then restart if the usb has reset on it then press
was the other mouse combo keyboard
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
Logitech Cordless Mouse Logo
529 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
