Question about Radio Shack Pro-95 Handheld Scanner
My handheld scanner
Ive got a model pro-95 that wont come of cole mode. theres no wire in it and it still wont come off clone mode. i need help !!!
I had the same problem...
The only solution I came up with was to find a 10-32 screw about 3/4 length to plug into the jack.
Doesn't look great, but it works.
Just take the screw out when you want to connect it back to the computer.
Posted on Jan 22, 2009
Try to reset the scanner and then reclone it
Posted on Sep 10, 2007
SOURCE:
Manufacture date for Radio Shack Pro-95, Serial # C062976
Check yahoo groups for RS or this model may help you or do a google search. JR
Jul 28, 2016 | Radio Shack Pro-95 Handheld Scanner
Pro-95 scanner can't unlock key pad can't reset can't initialize
my pro-95 has a locked number on the key pad--says=mooo**adl+*30375=bank 0 ch 00 ed: none can you help me get it unlocked ?
Jul 24, 2012 | Radio Shack Pro-95 Handheld Scanner
Pro 84 locked up says on screen in program mode wired
Your scanner should only enter the WIRED mode if you have a clone cable plugged into it. The only way to clear the problem is to RESET the scanner. Unfortunately this procedure will also erase all the frequencies that are programmed into the scanner. RESET is covered on page 54 of the scanner manual -- if you don't have yours you can download and print a copy here:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000516_PM_EN.pdf
Bill B.
Listening in since the 60's
May 27, 2011 | Radio Shack Pro-84 Handheld Scanner
My pro-95 scanner screen reads all channels locked out! How do I get it back to working mode.
hello firstly select the mode and bank number ,press and hold L/o button this will unlock all channels and ready for programming you will notice that the L/O button is now removed from the screen
goodluck
Apr 19, 2011 | Radio Shack Pro-95 Handheld Scanner
I have a pro 23 hand held scanner it scan but I only pick to weather channel. Thanks, George
You will need to program in your local channels - ANALOG ONLY will work, not Digital. I suggest you go to "Radio Refererence DOT com" and go to their database; select your state, then your county, and it will list many frequencies for you to program to your radio. Also, SOME, not many, but SOME, Radio Shacks actually have a ham radio guy working there that can help you program your radio or help you 'CLONE' it from another identical radio. Good luck, and let me know how it goes. Happy New Year my friend.
Dec 31, 2010 | Radio Shack Pro-95 Handheld Scanner
I have a pro 97 hand held cant get it out of clone mode
Your scanner is designed to automatically enter CLONE mode when a cloning cable is attached, and to exit CLONE mode when the cable is disconnected. If you do not currently have a cable connected, you will need to INITIALIZE your scanner to return it to normal operation. NOTE: Initializing the scanner will erase/delete all programmed data and return the scanner to its original factory settings. Before starting this procedure, be sure that you have a record of all programming information so that you can reprogram your scanner.
To INITIALIZE the PRO-97:
1. Turn the scanner OFF.
2. Turn the scanner ON. "Multi-system Trunking Scanner" appears.
3. Press the 0 (zero) key while "Multi-system Trunking Scanner" appears.
4. Press the 1 (one) key.
5. Press the ENT key. "Initializing please stand by" appears on the display for about five seconds.
Do not turn the scanner OFF until the initialization process is complete. When it is complete "M000" will appear on the top line of the display, and "Bank 0 Ch 00" will appear on the third line of the display.
Once the process is complete you can begin to reprogram the scanner.
Bill B
Oct 06, 2010 | Radio Shack Pro-97 Handheld Scanner
How do you set Pro-95 to receive police "Viper Channels" Mine, most of the time is static or beeping, Squelch doesn't help. Is there a software program upgrade for this. Located in Mooresville, N.C. 28117...
There isn't a Firmware upgrade for this scanner and I also do not think it is capable of Decoding these transmissions. My Pro-95 gets the beeps and tones also. This model of scanner was one of the last models R.S. produced before adding the digital capabilities.
May 09, 2010 | Radio Shack Pro-95 Handheld Scanner
How to clone 97 pro radio shack scanner
my husband had 1 of those.they do not work at all.
Sep 23, 2009 | Radio Shack Pro-97 Handheld Scanner
Stuck in the clone mode
Sounds like you need to re-initilize it... Not certain of the codes, but I'll look around and see what I can find for you.
Good luck.
Tom
Oct 23, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
73 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
