Question about Sharp Notevision XG-NV6XU Multimedia Projector
Sharp Notevision 6 XG-NV6XU
I recently purchased the above. It has 144 hrson the lamp. When I turn it on, the projector comes on and there's an image that comes one. No more than 5 sec's later, It powers down. I turn it back on and it shuts off right away. The filter is clean and secured well. Im confused.
  • 944 Answers
This sort of problem is almost always a lamp problem, regardless of the number of hours. The only way to verify this is to try the lamp in another projector that works fine, or a new lamp in yours. Testing the lamp in circuit is practically impossible for this model, and testing it out of circuit is unlikely to identify for sure what the problem is. If you need help sourcing a new lamp, please ask again and I will try to find you the best deal - prices vary wildly on these. Hope you can find another projector to test with :)
Posted on Sep 06, 2007
    President:
  • 1,114 Answers
Perhaps clean the side filter as well as per page E-46 in the manual on following link: http://www.fixya.com/support/t161763-sharp_notevision_6_xg_nv6xu You can find links to email support & FAQ's on this link: http://www.sharpusa.com/products/TypeManuals/0,1083,29,00.html
Posted on Jul 28, 2007
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Projector turns off after 3 minutes, lamp needs replacement?
Try reseting the filters for the lamp and also clean the air/dust filters.
May 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Recently I was using my xv-z90u, I started the projector up and turned it off right away and the bulb replacement lights started flashing and going into a standby mode(two red lights). So I replaced the...
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Jan 14, 2010 | Sharp Projector lamp Projector Lamp
Projector image burn (retention)
first off, make sure you got the right lamp and it's from sharp, not a "lamp store". the quality varies. it could be burning hotter than it's designed for. second, you may need to reset the setting to factory default (through the menu options). third, you may need flash upgrade. you'll need to contact a sharp service center for that.
Mar 28, 2009 | Sharp Projector lamp Projector Lamp
I have a second- hand dell 3100MP projector which I use during church services to project songs and other material. Recently it has been showing a predominalty green image , particularly when showing...
sir
the lamp is not at problem, but the dlp engine is at fault, u may have to replace it.since u bought it 2nd hand,it is not worth changing the same as it will cost u more than ur buying price.when u plan to buy ur next projector, make sure u buy a new one as it will come with a fresh lamp & manufaturers warranty on the unit & at 4000 / 5000 hours of projector usage is guaranteed!
Jan 05, 2009 | Dell 3100MP Multimedia Projector
Projector image going out
Hi DHova
This is most probably your lamp that is the cause of the problem.
Take out the lamp and check for any markings or discolouration or even a bubble at the end of the shaft. In which case the lamp will need replacement.
I'm sure this will be of help.
May 07, 2008 | Office Equipment & Supplies
Toshiba projector TDP-T30
i have the same one but it needs a new lamp i will buy one of your lamps off of you let me know a price
Nov 12, 2007 | Toshiba TDP-T30U Multimedia Projector
Problem with a Gateway 210 DLP projector
The color wheel may not be turning. Remove the lamp and see if it will turn manually.
Aug 08, 2007 | Gateway Projector 210 Multimedia Projector
Sharp Notevision XG-NV6XU Multimedia Projector Logo
174 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
