Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Impella separating from the motor shaft.
Is there a way to repair it instead of replacing the whole motor which is working fine (and costs about $100)? Does the impella and casing come off the rest of the motor without breaking it? If yes it could be possible to fix it back to the shaft.
  • LG Master
  • 909 Answers
SADLY THE REPLACEMENT PART IS THE ONLY WAY BECAUSE IS IS OFTEN PRESSED ONTO THE SHAFT AND ANY TYPES OF GLUES OR APPOXIES WOULD NOT WORK DUE TO THE HEAT OF THE ELEMENT.IF IT DOES HAVE A THREAD IT MUST BE PARTIALLY STRIPPED BECAUSE THE THREAD IS USUALLY REVERSE THREADED. (IT SHOULD NOT COME LOOSE)
Posted on Aug 23, 2007
SOURCE:
Volvo windshield wipers don't work
From the wiper motor, the wiper linkage attaches to both wiper arms. If one side is working, then that indicates that your motor is working, and the linkage to at least 1 wiper arm is working.
What's left? The linkage to the other arm, and the connection of the arm to the pivot shaft assembly. Let's find out:
1. Remove the inoperative wiper arm. You will expose the shaft that the wiper arm attaches to. It will have a head on it that looks like a small peanut butter cup, with shallow ridges or splines all the way around it. This can be formed on the end of the shaft, or it can be a separate piece that is removable. If you don't see it, it may have come off with the wiper arm, so look for it to be still embedded in the wiper arm hole. Once you find it, how do those splines look? Are they stripped? If so, they may be rotating within the arm instead of rotating the arm itself.
2. Run the wipers again. Is the shaft rotating? If it is, then the arm and/or splines were the problem, and you need to replace withever component had the stripped splines, whether the arm or that p-nut butter cup splined part. (Or both, if you want to be extra safe and not have to mess with it again for a while.) If you're lucky, it'll be a separate piece that you can replace easily. If not, it'll be formed as part of the wiper linkage, and you'll have to replace the whole linkage. If it's just the arm that's stripped, replace the arm. Easy.
3. If the shaft does NOT rotate with the arm removed, then the linkage is broken, usually at the connection where the wiper shaft connects to the long arm that hooks both wiper shafts together. The bushings are often plastic, and they wear out. If it's plastic, you can get a replacement at the dealer, which will be nice, new plastic to last however long this one did. But if the linkage is metal all the way along, you'll have to do more work than with the easily replaceable plastic connection.
3b. To gain access to the linkage on most vehicles, remove both wiper arms. Next, remove the (usually) black plastic vented piece under & around the wiper shafts. This should allow access to the wiper linkage.
For those who who have neither wiper working and were hoping this would cover it, you're in luck. If neither wiper is working, here's how to test the system:
1. Turn the key to ON.
2. Turn on the wipers.
3. Listen for the sound of the wiper motor. LIsten in the cab, but also in the engine compartment as well. If you hear it but have no wiper movement, your motor is fine and the linkage is the issue.
3b. If you do not hear any motor sounds in the cab or the engine comartment, it's either the motor or the switch (I assume you've checked the fuse already).
4. Check the wiper motor: Does it have a connector for the wires, or just one wire. If it has one wire, remove that wire and check it for voltage with a multi-meter or test-light. If you have a connector, you'll need to know what wire is which. Maybe. Most of the time, the motor is grounded thru the body, so if you remove the bolts and move the motor away from the body, you can check for voltage between the motor and body.
5. If you have no voltage, then it's the switch or wiring, or possibly the resistor, if equipped. If you DO have voltage at the motor, but no motor movement, the motor is bad and must be replaced.
Apr 19, 2013 | 1996 Volvo 850
How do I remove the Impeller of my aquaflo flomaster pump? I have the pump open, and I loosened the 4 screws at the base of the motor so the volute spins freely, but the impeller isn't detaching. Bruce...
At the end you loosened the motor thru-bolts you should have a cap covering the motor shaft end. Remove it to find the end of the shaft. Depending on the motor brand and age you should have either a flatted surface for a wrench or a slot for a screwdriver to secure the shaft from turning. Turn the impeller off counter-clockwise. Some impellers are so stuck you can not free them holding the shaft end this way. Disassemble the rotor from the pump motor and lock the whole works in a vise to then get a better grip on the impeller. Impellers are often cracked from seal failure so do not be surprised if your impeller breaks up before coming off the shaft.
The replacement part number is the 8 digits you will find molded into the impeller plastic. For a quote on a replacement part(s) please contact us thru www.arrowpools.net.
John
Nov 10, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
How do you get the impella of a jacuzzi lr swimming pool pump
looking at he face of the impeller turn counter clockwise, with a large set of CHANNELLOCK 20" Pliers Channel Lock Model 480 cost about $70.00 there is a notch on the back of the motor shaft for ether a 1/2 or 7/16 open end wrench to fit in to hold the rotor from turning. warning ! these pumps are hard to find parts for so you want to have the right tool so you don't break anything. your best bet is to bring it to your local pool pump motor repair guy and have him do it, if its just the seal you are trying to replace it should be a $20 job
if'n i was any help vote ... thanks ..jay .. and prime the pump after a repair !
Jun 08, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Ras8445jq0 wont spin, agitates fine, replaced timer, lid switch is good tried manually jumping lid connector as well and no luck, motor isn't running or anything, but all other cycles work fine only sping...
You need to replace the direct drive coupling on the shaft of the motor. I have attached a breakdown for you. Number 13 in the picture. Not a costly repair.250
Nov 19, 2009 | Maytag Washing Machines
Drivers wiper won't move. passenger wiper does. 2002 toyota corol
You don't have 2 motors; only 1. ...well, 1 front, 1 back, if equipped. From the wiper motor, the wiper linkage attaches to both wiper arms. If one side is working, then that indicates that your motor is working, and the linkage to at least 1 wiper arm is working.
Jun 13, 2009 | 2002 Toyota Corolla
Impella shaft wear
no specifications on wear by factory, but if the shaft shows sighs of wear...out of round...grooves etc you will need to replace...if there is any side to side(up-down) play then the oil seals need to be replaced
Mar 01, 2009 | 2002 Yamaha YZ 426 F
02 explorer.no heat,makes thumping noise when temp turned to heat
  The concern lies in the temperature blend door. Most likely if it is clicking the door is broken where the motor shaft (the motor that actuates the door) goes into the door. Replace both the door and motor ( unfortunately from Ford the whole heater box needs to be replaced) or an aftermarket such as Dorman may have the door separate.  The entire dash needs to be removed for the repair so it is quite costly.
Sep 20, 2008 | 1998 Ford Explorer
Driver Seat power problem
It started working on it's own!!! The dealership doesn't repair this kind of thing-only replace it. They first quoted $1200 to fix (as the whole seat/subframe- i.e. all 3 motors- had to be replaced), then between $550-$600 (as they found out only the front motor had to be replaced). I have taken the seat out several times- tapping the motor, twisting the 2 shafts, wiggling the wires, cursing it..... I finally got it to work, but only on one side (i.e. the seat would twist on its track instead of moving front and backwards "evenly". Then, out of the blue it started working again on it's own. I guess it's time to trade the thing in while it's working. For some reason, having someone sitting in the seat (while you're hitting the switch) seems to help the motor activate. Hope this helps.
Sep 03, 2008 | 2004 Infiniti I35
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
49 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
