Question about D-Link DIR-625 (790069292637) Wireless Router
Can't seem to change security level
I HAVE A D-LINK 625 WIRELESS ROUTER. WHEN I SETUP UP THE DEVICE ON MY COMPUTER I CHECKED OFF " MOST SECURE LEVEL"
NOW I FIND THAT I AM NOT ABLE TO USE MY IPOD-TOUCH SINCE THE MESSAGE STATES THERE IS NO INTERNET CONNECTION. MY FRIEND SAID IF I LOWER THE ENCRITION LEVEL TO THE LOWEST POINT THAT THIS WILL TAKE CARE OF THE PROBLEM.
THANK YOU
  • Peter Steiert
    Peter Steiert May 11, 2010
    Uhm, no. Lowering the encryption is not something you want to do. Probably what happened when you selected, "Most Secure Level" is that your connection was encrypted. This is NOT a bad thing!
    What you need to do is figure out what your router's security code is and which encryption type it is using?
    For example, figure out if it's using WEP or WPA. Then figure out which channel the router is using to broadcast the wireless signal. Then find out if the router is using Key 1, 2, 3, or 4 for the wireless encryption password. Then find out what that key is.
    Afterward you should be able to give that information to your I-Pod to connect to your wireless router.
  • 36 Answers
You have a d-link 625 range booster? if i am not mistaken the most secured level encryption is WPA2.. MOST apple ipod touch does not support WPA2 encryption, most only support WPA encryption.. try setting your security level to Medium or lower your encryption to WPA.  If it still does not work, try the Lowest Encryption.
if this does not help, try using WEP
Posted on Feb 02, 2009
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
I can't connect from my wireless
connect through a wire and go to the setup page 192.168.1.1 log in and change your wifi key to your cell phone number and use WEP protection or AES
Mar 02, 2011 | D-Link DIR-625 (790069292637) Wireless...
How can I create a secure code?
IN order for you to enable wireless security on your network you need to access the router setup page where you can setup all the settings for it including the wireless security
So to do that access the router setup page and once there look for a wireless portion on the setup page and from there you will be able to see the place to enable WEP or WPA I suggest you use WPA which is a much stronger level of security that you can use.
Dec 04, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
How to secure a D-Link DIR-625 router?
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
How setup the password and lock the wireless
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Sep 16, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have a DIR-625 N router and am unable to secure it
Hi dakingma1221,
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
You may also connect using the NetBIOS name in the address bar (http://dlinkrouter).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default. Type in the graphical authentication code (if you cannot read it, click Regenerate).
To run the security wizard, click on Setup at the top and then click Launch Wireless Security Setup Wizard.
Click Next to continue.
Enter the SSID (Service Set Identifier). The SSID is the name of your wireless network. Create a name using up to 32 characters. The SSID is case-sensitive.
Select the level of security for your wireless network:
• Best - WPA2 Authentication
• Better - WPA Authentication
• None - No security
If you selected Best or Better, enter a password between 8-63 characters.
If you selected Good, enter 13 characters or 26 Hex digits.
If you selected Better, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
Click Save to finish the Security Wizard.
If you selected Best, the following screen will show you your Pre-Shared Key to enter on your wireless clients.
If you selected WPA-Enterprise, the RADIUS information will be displayed. Click Save to finish the Security Wizard.
Good Luck,
Don't forget to leave a rating,
Thanks
Mark
Sep 18, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-link Router DIR-625 resets itself
You need to open the router's setup page (admin page) http://192.168.0.1 to enable the wireless security
Feb 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 - Unsecure connection
How do you know that you are connecting and there is no security? There first thing to check is the router settings. You should type into the browser 192.168.1.1 (or whatever you have configured your router's IP address for). Enter the user name and password for the router. On the next screen you will notice a link for wireless settings. Click this and on the new page check the bottom section that says "Wireless Security Mode". It should be set to something other than "none". Post back and let me know what it is set to.
Nov 20, 2007 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
275 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
