Question about Canon EOS-10D Digital Camera
Err 99 when I attach lens
My camera works perfectly when i dont have a a lens on it, but as soon as i put on my Canon 80-200 lens, it wants to flash Err 99. WTFreak?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
I had the same problem with my camera and i found this guide online very helpful in most cases
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
Posted on Jan 29, 2009
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
Does the "ERR 99" message appear? If so, then the CF card is the most
camera body.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
Err 99 in canon 350D
Apr 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
camera body.
Aug 31, 2008 | Canon EOS-20D Body only Digital Camera
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99
Although you may have cleaned the lens contacts, did you clean the camera contacts? This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
camera body.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
From RICHARD'S NOTES
Dec 04, 2007 | Canon EOS-10D Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Canon EOS-10D Digital Camera Logo
142 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
