Question about Roper REX4634KQ Electric Dryer
Dryer runs but doesnt heat
Dryer runs its normal time but never gets hot. i checked the vent and it is venting like normal i unplugged it for a while and back in and it still will not heat.
  • Anonymous Jan 31, 2009
    never gets up to temp
    Novelist:
    Habit-Forming:
  • 112 Answers
CONSIDER THIS FIRST
BOTH LEGS OF AC MUST WORK TO GET HEAT FOR DRYER Maybe the wall receptacle has no power on one of the 110 volt legs. Both legs of the 220 volt AC have to work go get heat. Only one leg is used to run the motor etc.. Your motor runs so this can fool you into believing that the electrical connection is ok when it really is not. Your dryer is on a double circuit with two breakers. If one fails you lose one 110 volt leg which can be the one giving the full 220 Volt needed for the heater. This happens quite frequently and people mistakenly replace heating coils. You could have a bad breaker, one of the two. You must check this first before assuming anything else. Get help if you are uncomfortable with potentially deadly voltages
Posted on Dec 15, 2015
    Habit-Forming:
  • 76 Answers
There are several problems that could cause your dryer to run but not heat, here are the most common to check for follow this guide:
Electric Dryer Runs But Dont Heat
Posted on Dec 12, 2015
    Genius:
  • 2,920 Answers
Check the heating element and the limit switches there are the first things to look for when theres no heat
Posted on Jan 29, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
HEAT TO MUCH
Hi rcantu4444...
Dryer Running Hot
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
May 16, 2011 | Whirlpool LER4634J Electric Dryer
Back of dryer getting very hot and keeps tripping the heat switch works fine not for long without overheating
Dryer Running Hot
May 16, 2011 | Dryers
My whirpool is not getting hot enough to dry the clothers
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum. Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Feb 13, 2011 | Whirlpool Dryers
Takes to long to dry
Hi, well this could be caused by a few different things. First one of the most important things to check is airflow out of the dryer, if it doesnt have easy exit of all of the moist air it will take longer to dry. first take the vent hose off of the back and feel if there is air exiting the dryer, it should feel like a fan on high coming out of the vent, if there is, check to see if it is hot at all. if it is hot and blowing fast then you will need to check your vent hose to see if it is plugged with lint. and also if there are many bends and kinks this will slow airflow. If you cant feel any heat it could be that the heater element is not cycling, this would be caused by a faulty thermal fuse or thermostat which both can be tested by and ohm meter and replaced, or it could be a faulty heater coil which can also be ohmed with a meter by putting both test leads on both connectors and checking for continuity. As always these steps should be done after unplugging the unit. These are sometimes difficult tests so if you do not feel comfortable doing these tests you can call your local appliance repair facility. Good luck.
Dec 09, 2010 | Maytag PYE2300AY Electric Dryer
No heat
Hello again,
Depending on your dryer type, if you do not have a front access panel, you should have a small peep hole. There is a small round or square hole with a pop-off cover that you can remove to view the igniter glow and light the burner. This should be in the lower front, so you shouldn't have to move the dryer or unplug it just for this.
Normally a poor heating dryer is the result of a blocked or clogged vent. When was the last time you cleaned it out. Over time it gets lint build-up and needs to be cleaned out once a year. Unplug the dryer and pull ot out from the wall. Turn off the gas too and be careful not to step on or kink the gasline. Pull off the venting from the backside of the dryer itself and using a flashlight, clean out all the lint. Do the same for the vent tubing you disconnected. Note: If you have an expandable plastic or foil vent tube hooked up behind your dryer, be sure it is not getting squished when you push the dryer back into place. After you're done reassembling it, fire it off and go outside and check that the vent cap 'flaps' opens with the hot air and has no lint build-up there as well. Then let me know if this makes a differance for your drying time or not. Good luck! Douglas
Jun 03, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer not drying in alloted time
there is a thermostat. it usually is located on the heating element housing
May 26, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
May 31, 2009 | Frigidaire GLER341A Electric Dryer
I have a whirlpool dryer model #len 2000pgo and my wash doesnt get dry but dryer gets warm ...not hot like it should. what could be wrong??? its electric
Your venting plays a huge part here.Do you want to be 100% sure about the vent ,ok,for just ONE load remove the vent hose from the dryer keep atleast 3 feet clear for the air to exit dryer.Now select TIMED dry cycle for 60 minutes.Start dryer and make sure your in a heat setting (not air fluff).The normal load should dry in 60 min,If it does than you now you have a block in the venting.
May 23, 2008 | Whirlpool Dryers
Roper REX4634KQ Electric Dryer Logo
164 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
