Question about HP Officejet 6310 All-In-One InkJet Printer
My new 6310 HP won't receive faxes.
I justinstalled a new 6310 HP. I can send faxes but it won't receive faxes. What can be the problem and how can I solve it?
  • 55 Answers
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
Posted on Jan 29, 2009
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
How to access the fax log on 6310 HP all in one
Hi ,
click on the hp director icon on the desk top or access it from start ?all programs?hp?hp director then in the hp director click on settings after which you will get the drop down menu ,select fax settings and setup and then click fax log.This is how you can access fax log and then you cal calso receive and send ..
hope this helped you call the best
May 11, 2010 | HP OfficeJet 6310 All-in-One Printer...
HP Officejet 6310 All-In-One InkJet Printer Changed home telephone system and now I can send faxes out but cannot receive?
Hi
Check the following link
CAN SEND but CANNOT Receive
  1. Make sure that the fax header contains the full 10-digit telephone number of your HP fax product, including the area code. To modify the fax header, use the following steps:
    1. Press the Setup button () on the product control panel.
    2. Press 4 for Basic Fax Setup, and then press 1 for Fax Header.
    3. Type personal or company information using the keypad, and then press OK.
    4. Type the phone number, including area code, for your HP fax product, and then press OK.
  2. Dial 1-888-HPFaxme and send a fax to the HP Fax Test Service.
Jan 04, 2010 | HP Officejet 6310 All-In-One InkJet...
Can no longer send/receive faxes since switching to digital phone
hi
fax does not work on digital line it only works on analog line........if u want our technician expert then contact us athttp://tinyurl.com/ldnuy2
Jun 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Can't send nor receive faxes w/my HP6310. It says shutting down.
Try to reset the device. # and 3 simualtenusly.
#6 is a partial reset
#9 is a full reset
May 06, 2009 | HP Officejet 6310 All-In-One InkJet...
HP officejet 6310 cannot fax
did you have fax service on the line?
Jan 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
893 people viewed this question
Seeker5211
Seeker5211
