Question about Pioneer DEH-P9300 CD Player
CANT GET SOUND
I have a PIONEER DEH-P9300 deck and recently it just stop playing sound..i can connect a speaker to one set of wires and hear noise but no words from cd, i was wondering what the problem was and could it be fixed or alterterd another way besides the speaker wires to get sound out of it? If any one can help please reply Thanks
  • 156 Answers
This is often caused by a shorted speaker wire. If you have a pinched or loose speaker wire that's touching metal, it will cause the deck's internal amplifier to shut off. If you have a multimeter available, disconnect the deck then check each speaker wire for continuity with the chassis ground wire. If you don't have a meter, you can disconnect all the speakers, then connect them again one at a time. See if you can tell if there's one speaker that kills the deck's output.
Posted on Jul 30, 2007
SOURCE:
Pioneer DEH-X6500BT amp & speaker problems
Depending on the car and your setup sounds like the amplifier is not wired properly or an issue with adjustments on your deck itself. More info on your sound setup would be helpful.
Dec 28, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I bought the deh-2200ub to replace an infinity stereo in a 2005 kia optima. There's less wires on the pioneer, which I just taped off, I have no sound. AARRRGGGGGG!!!! help
Hi, the wires should be connected as indicated below. Please let me know if you have questions, and thanks for using FixYa.
2005 Kia Optima Car Stereo Wiring Schematic Pioneer wire color
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: Yellow red
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Brown/White none
Car Stereo Dimmer Wire: Gray none
Car Stereo Antenna Trigger Wire: Gray blue/white
Car Stereo Amp Trigger Wire: Green blue/white (same as above)
Left Front Speaker Positive Wire (+): Yellow white
Left Front Speaker Negative Wire (-): Black white/black
Right Front Speaker Positive Wire (+): Blue gray
Right Front Speaker Negative Wire (-): Red gray/black
Left Rear Speaker Positive Wire (+): White green
Left Rear Speaker Negative Wire (-): Brown green/black
Right Rear Speaker Positive Wire (+): Orange violet
Right Rear Speaker Negative Wire (-): Green violet black
Apr 10, 2011 | Pioneer DEH-P4000UB CD Player
My pioneer deh-p840mp powers on and flips open, and seems to function fine with the exception of no sound going to all my door speakers and the bass to my subwoofers is a far sounding muffle even as I turn...
Un hook all your speakers that the deck is powering and hook them up one by one sounds like u have a shorted speaker or wire and the unit is going into protection.The best way to chk the speakers and wires is with an ohm meter . Check each speaker wire to ground and across the speaker and see iof you have any shorts. The next step woulk be to remove the unit and have it bench tested.
Jul 30, 2010 | Pioneer DEH-P840MP CD Player
The speakers are hooked but theres no sound
Here's a few things to check:
1. make sure the polarity of your speaker wires is correct at all the speakers. If you've accidently connected a speaker + to a ground, you'll lose sound.
2. With the deck playing, disconnect one speaker at a time to isolate the problem.
Nov 27, 2009 | Pioneer DEH-P4600 CD Player
Everything works the speakers are hooked up i just
connect one speaker at a time .If one speaker or speaker wire is bad it will cause all audio to mute.connect one speaker at a time
Jul 30, 2009 | Pioneer DEH-P3500 CD Player
I have a used pioneer cd deck. No sound to speakers
The blue wire would be your remote wire to hook up a amp and if you have a wire harness all you have to do is match the colors up.
May 14, 2009 | Pioneer DEH-P3100 CD Player
Color code from stereo to speackers
set ur stereo to play sound the the rear left then try the wires when u hear sound you know thats the rear left wires, then do right front etc etc, the colours will be in pairs like gray then gray with black line would be 1 speaker
Mar 19, 2009 | Pioneer DEH-P6600 CD Player
Pioneer deh-p9800bt is makeing a bad noise thrrough my speakers
Since vehicles started using High Energy Ignition engine noise in stereo equipment has been a issue. You have two options. The first is to try connecting your power wire to a alternate source that may have internal filtering. If you cant find a clean source of power you will have to add a inline filter on your power wire. You can pick them up at any stereo shop.
Nov 20, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Deh-p7900bt no sound
lol... i had the same problem...
there is a blue wire in the TRUCK ADAPTER HARNESS side.. thats the amp remote or turn on..
make sure to connect that to the blue or blue/white "remote" wire on the deck.. that should do it.. unless you fried the audio ic chip in the deck...
if you cant figure it out please dont rate me "unhelpful" thanks
Jan 05, 2008 | Pioneer DEH-P7900BT CD Player
Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Jul 18, 2007 | Pioneer DEH-P3000 CD Player
Pioneer DEH-P9300 CD Player Logo
103 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
