Question about One For All URC-3021 Remote Control
When tv is turned on it goes back off
Also need codes for remote control to work.
  • 11,896 Answers
What kind of television do you have? Need this info for remote
If your tv is turning right back off, it is very possible your power supply or capacitors are burning out
Posted on Jan 29, 2009
Tip
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
on Jan 18, 2010 | Televison & Video
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
I need some codes for my RCA t.v. remote control product # inside control - rcr312w or r20052 3912p
You can auto search for the code. Here are the instructions.
1. Turn on the device you want to program i.e tv
2. Press and hold the tv button (the on-off will light up)
At the same time, press and hold the on-0ff button for three seconds. (It will initially go off then come back on.)
3. Release both buttons and press the Play button. If your t.v. goes off or even goes off then on, proceed to step 4. If not, repeat step 3 until it does.
4. Now that you have found the general code, you need to set the specific code. Press and release the reverse button until t.v. turns off. Once you have found the code, you need to lock it in.
5. Press the Stop button. Then test your remote.
For more detailed instructions go to: http://www.vosssupport.com
Oct 05, 2009 | RCA Universal Remote Control
Need codes for LXI tv/vcr combo
you need to hit code search and hold it in untill the light lights up and then you hit button that says tv and then keep hitting power untill tv goes off but dont hit the button after the tv goes if you do you will have to restart and after the tv goes off then hit enter and then turn the tv back on and then you can control the tv.
Jun 15, 2009 | One For All URC-3021 Remote Control
Remote codes
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Jan 03, 2009 | Bell SH50102 Remote Control
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
Nov 29, 2007 | GE JASRM24912 Remote Control
One For All URC-3021 Remote Control Logo
27 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
