Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 convergence board...add'l question
I am having the same problem with the red lines not aligning when doing the convergence procedure. When watching TV their is an awful red hue or shadow on the screen. This is the post that I have questions about: "Order online part # SSB-5068A. This is the ENTIRE convergence board with new IC's. Cost you about $140 (from vance baldwin.com) but is a lot less hassle than you trying to soldering/desoldering parts. Only thing is, next to the 2 large heat sinks, there is this large silver component that you need to unscrew from your old board, and unplug and attach to your new board." 1. The baldwin link... http://www.vancebaldwin.com/products/?SSB-5068A-M2-R&t=P * it has a different part number than the ssb-5068A, the link shows SSB-5068a-M2-R. Is this the same part? If not, I am not able to locate the part. 2. What does the convergence board look like behind the tv?
I just removed both of my 110 IC's and replaced them with 150's. However in the process of removing the solder from the old board, I may have damaged the pads/vias where the pins make contact. Be careful of this when removing solder. I also blew 5 resistors after plugging in the new IC's.
Posted on Aug 05, 2007
SOURCE:
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 06, 2009 | JVC AV-56WP74 56" Rear Projection...
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
JVC 56 inch projection AV-56WP74 red color not aligned
I have the same tv set and about 4months ago Ihad the IC STK392-110 replaced. I was told that it was the most common problem with proj. tvs. It did solve the probem until last night when I went into the menu to change a audio setting and stupiditely accesed the convergence setting and decided to do an auto adjustment which mesed up my beutiful HD picture. Now I have the red out of alignment ad even after I did a reset and multiple manual adjustmets it is still off at the top and bottom af my screen.
Dec 27, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc 56wp74
sounds like a solder related issue on the convergence ICs. They are acessed through the front of the TV behind the speaker grille and then remove the small acess panel and you will see the convergence amp board with the two ICs on it.
Oct 26, 2008 | JVC AV-56WP74 56" Rear Projection...
IC's
Take the board out through the front inspection hole. No screws holding board. Middle large plug disconnects from chassis, not converge board. All other plugs come off converge board.
If the large plug is a problem, just hang out the front and solder.
Be careful with foil on board, crappy board.
Pacific Semi for ICs.
easyab
Jul 29, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV 56WP74 Problem after fix
Will the colors move into alignment controlling them manually?
If you can get the colors to align but they simply won't hold it's a matter of programming. If they won't align you still have a failure in the convergence circuit. If red or blue will only move so far but not close enough to align you have an amp problem.
Bill
Mar 31, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56 in
You don't have to replace the board, just the amps. This set uses two stk392-110 Sanyo built amps. You will also need to test and possibly replace one or more of the 1.5 ohm feed resistors in that circuit.
If you're doing this at component level try Acme in Florida for amps and resistors: 1-800-575-9833 http://www.acme-sales.net/index.shtml and if you're doing this at modular level send it to PTS http://www.ptscorp.com/ 1-800-844-7871
Bill
Nov 27, 2007 | JVC AV-56WP74 56" Rear Projection...
Double vision On JVC AV-56WP74 56
You have an convergence problem, There are 2 IC's that go bad and a few resisters that can change value. If you flip the board with the Chips inspect the pins for cold solder joints. The IC's can be purchased from matelectronics
Jun 17, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
2,185 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
