Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
Samsung HC-P4241W 42 in. Rear Projection CRT aging
I HAVE A SUDDEN AGING PROBLEM OF THE CRT AS IT IS ONLY 2 YEARS AGO I BOUGHT THE PROGECTION TV HC-P4241W. THE AGING APPEARS TO SHOW DISTORTED IMAGES, MORE DETECTABLE IN THE TEXT, FOR EXAMPLE THE NATIONAL GEOGRAPHIC LOGO IS SEAMS TO BE LIKE A DOUBLE IMAGE, IT IS NOT SO EVIDENT BUT THE PROBLEM IS THA IS A HIGH DEFINITION TV AND THIS IS NOT SUPPOSED TO BE SEEN. THANKS
  • Anonymous Aug 08, 2008
    Ghost Image on the letters and blue in the background
    President:
  • 3,130 Answers
First off, do you not know Internet etiquette? Caps are considered yelling or shouting! So please! head You have the typical convergence failure of the convergence correction IC's. They BOTH need to be replaced. If you have no solid state printed circuit board experience, play it safe and call in a pro to assist you in this repair. Good Luck
Posted on Jul 28, 2007
See add details
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 08, 2010 | Samsung HC-P4241W 42" Rear Projection...
Samsung lcd TV five years old, screen suddenly went black
In order to properly provide you with guidance, we need some hint about the problem. Can you describe the symptoms? Is the set dead? Are there any blinking status lights?
Thanks,
Dan
Sep 20, 2009 | Samsung HC-P4241W 42" Rear Projection...
Hi, my tv hc-p4241w was ok but one day, the picture in the screen become wide and then I saw smoke from the rear panel. I switched off the TV, and I found that the C407 have exploded, there's a Diode...
Look to see if any coolant fluid has leaked from any of the CRT's. This is a common cause of multiple component failures in these models. Look real close at the CRT mounting bracket, the wires coming from the CRT's and look at the particle board below to see if you can see any staining or puffed up wood particles. My experience with the Samsung bds is when you have a multiple compoment failure due to fluid leakage it is best to replace the boards instead of component level repair because other components will fail at a later time. Coolant fluid is real hard to spot since it is ultra clear. Hope this helps.
Jul 13, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w problem
Look for 2 Big black chips they will be together on convergence broad STK-392-110s,120s replace both ics.Use STK-392-180s
Mar 29, 2008 | Samsung HC-P4241W 42" Rear Projection...
HX-P4241W appears yellow. Left and Right of screen are yellow
Yellow is the lack of blue. It can happen when you are running your contrast - which is your overall light level - too high.
Try turning down your contrast. On CRT tech, contrast should always be run at half what the factory allows as full, on the user controls. Full up is what calibrators call Torch Mode, and is NOT the way to get performance to be in the linear operating range of CRT tech.
If your sides are more yellow than your middle, your set may need lenstriping. Mild yellow on the sides is not uncommon, and usually not noticed. But heavy yellow on the sides would indicate that the blue image needs work on white field uniformity.
Yellow is the lack of blue, in CRT tech.
Mr Bob
Feb 02, 2008 | Samsung HC-P4241W 42" Rear Projection...
HC-P4241W
you need to replace STK 392-110s these are your convergence chips and will cause this problem some are stk 120s 150s,up grade to 180s.
Jan 08, 2008 | Samsung HC-P4241W 42" Rear Projection...
SAMSUNG 42inch HC-P4241W MODEL CRT AGING
explain what the picture looks like? Does it look like the edges are in 3-D?
Jul 25, 2007 | Samsung HC-P4241W 42" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at nicodhem@yahoo.com
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
596 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
