Question about KDS Valiant 6380iPTD-01 Notebook
Window does'nt wind
I have a 1970 vg sedan and the back window stoped working and slides down by its self?
Why self timer is not stoping. why self timer is not stoping. why self timer is not stoping. why self timer is not stoping why self timer is not stoping
I don't know, I don't know. I don't know. Perhaps you could tell us what brand and what model camera you use? And perhaps you can tell since when it is acting strange? like after you dropped it, or after it went down in the swimming pool. Or perhaps just after leaving it alone for a few days or weeks. Or perhaps after you changed some settings?
Apr 25, 2014 | Cameras
Two weeks ago the drivers side rear wind stoped operating and is in the up position. All other windows were working ok. Yesterday the passanger side rear window stoped operating. Fuses are ok and I hear...
Not really i think your right, it sounds like both motors went bad a quick little test i always do is hold switch down and bang on the inside of the door at lower front of door and sometimes it shakes motor and it starts working then i know for sure its a motor, this save cuatomers money , they dont pay to remove panel and testing,try it . hope this helps.
Aug 29, 2010 | 2006 Lexus Es 330
Microsoft window Ehl.exe has stoped working
>>Right click "Computer"
>>Click "Manage"
>>Double click "Users and Groups"
>>Click "Groups"
>>Right click "Administrators"
>>Click "Add to group..."
>>Click "Add"
>>Click "Advanced"
>>Click "Find Now"
>>Double click "Local Service"
>>Click "Ok"
>>"NT Authority\Local Service" should show up in the list now
>>Click "Ok"
>>Close Computer Management and reboot.
For users with the Home editions of Vista:
Go to the command prompt (hit run and type in cmd.exe)
and type this in:
net localgroup Administrators /add Local Service
then you can type this in:
and if LOCAL NT AUTHORITY/SERVICE is listed, then it worked. Now go reboot.
Apr 01, 2010 | Computers & Internet
My men's presidential date just is very difficult to wind. I try to wear it often, but it quits. The winding mechanism is so stiff that I can only partially wind it. It does move easily in the oposite...
If it has only recently gone stiff then it sound like a trip to the dealer for repair.
It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
Could it be that you need to pull out the crown to wind it?
Feb 03, 2010 | Rolex Mens Super President, 18kt YG
Juts got the watch, wound it, worked then stoped, wound dead
These watches are self winding (mechanical spring), so need to be worn (or gently oscillated) to wind them up.
The catalogue for this watch says it should run for 72 hours when fully wound.
Depending on when the watch was made, it could be that it needs a clean.
Try wearing it for a few days to see if it keeps going.
Feb 02, 2010 | Rolex Daytona 116520 Wrist Watch
My Fossil VT2657 no longer works. I can see no physical damage, but it hasn't been used in years. I'm not even 100% sure how to wind it, but after quite a bit of winding in both directions it still...
it has a battrey or and atomatic winding gear. watch makers a stoped self winding watches due to people over windinfg and braking the watch. check battery it might be dead. or just shake the watch back and forth untill it starts again
Jul 12, 2009 | Fossil VT2657 Pocket Watch
Windows intenert is stoping
Is your problem "windows close" or laptop shutting down when you on the internet or just working on the windows?
First, could be virus or software issue.
Second, could be memory issue.
Nov 29, 2008 | Gateway ML6732 Notebook
1970 Cadillac Deville Power Windows and head lights.
try to replace the battery??
and chek all the connections!!
Sep 07, 2008 | 1976 Cadillac Deville
Need to activate my new Locman 1974 self winding watch
this website may be helpful to solve your problem
http://www.finewatchmaking.com/
Aug 18, 2008 | Watches
Bobbin is not winding correctly
slide plate may be worn - i had the same problem. try holding down the center of the bobbin with a pin while slide plate is in the winding position.
Dec 31, 2007 | Singer Featherweight 132Q Mechanical...
KDS Valiant 6380iPTD-01 Notebook Logo
194 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
