Question about HP Compaq Presario CQ50-211NR Notebook
Not booting up; stopping at white Compaq screen
When we start the notebook up it turns on the beginning "compaq" screen and then stops. I've tried pushing f10 or f2 and it notes at the bottom left of the screen that I've hit the button, but it doesn't do anything. The notebook is a compaq presario cq50
  • jes380 Feb 09, 2009
    Wont boot. Power lights go on hard drive light blinks and spinout is heard for a second and Compaq logo shows up. Lower left corner says press esc for startup menu. Pressing f2, f10 or f8 doesn't produce any effect. When hdd is removed. Reseated memory and nothing changes.
  • reinaldo mam Mar 21, 2009
    mi laptop esta bloqueado de usuario
Called HP after doing all troubleshooting steps described in their product page. Technician had me re-do some of those steps (reseating memory modules, removing and reseating hard drive, removing battery and power adapter and pressin power button for 40 secs.) and they ended up asking me to send the computer back to them for a Motherboard replacement. I had a similar case whith an older presario computer and they did the same thing. Researched and found out that the motherboard goes bad due to thermal issues. (I kindda hoped they would solve that on future models but apparently the problem is still there).
Posted on Feb 09, 2009
  • 741 Answers
F10 is the correct key to press to get into BIOS for Compaq, but there is nothing in BIOS that can help your computer boot all the way up. Instead press F8, this will get you into Safe Mode. Then do a "restore" it will restore your system to an earlier date before you were having problems. Here's how you do it:
Start the computer and press F8. Safe Mode.
Then allow it go into Windows. Then click on start>programs>accessories>system tools>System Restore. It will ask you for a restore point date, just make sure it is before you started having problems. This should work..let me know if you have any questions.
Before logging out, please rate this solution with 4 stars.
Posted on Jan 29, 2009
  • HP Master
  • 2,404 Answers
Take out the hard drive. Then turn the notebook back on and see if it goes past the Compaq screen. If it does then you know your hard drive is bad and it would have to be replaced. It could be shorting out the motherboard.
HP Compaq Presario V3000 PC Notebook - Screen Blank, Won't Boot
try to put the windows installer, and re-install again your OS.. format the drive and install a fresh copy of windoes..
Jul 02, 2008 | HP Compaq Presario V2000 Notebook
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
Compaq presario fan stopping
Take it back to the place of purchase since it is under warranty, otherwise you will damage the processor which the cooling fan protects.
May 03, 2012 | HP Compaq Presario V2310us Notebook Pc...
The screen went blank when I was using the laptop and know it won
You are experiencing power supply failure. The main board may not get the right power to boot up the devices. You need to refer your product to a qualified servicemen. Problem can be solved online.
Thanks. Cheers!
Apr 21, 2010 | HP Compaq nc6000 Notebook
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
I have a hp Compaq 6735s...it refuses to start up...when it passes the post screen it does not show...but i tried booting from safe mode it boots normally...i then repair the OS thinking it was gonna stop...
can you access bios screen (hold f10 during startup)? if so go there and test memory modules (run in test) and this also will test hdd. can you see any blinking/lit leds? then give me more info.
Sep 25, 2009 | HP Compaq 6735s Notebook
Laptop screen turns white
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Feb 24, 2009 | Compaq Presario X6000 Notebook
HP Compaq Presario CQ50-211NR Notebook Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
