Question about Acer X193W LCD Monitor
Color is too yellow
I just set up my acer 19" monitor but the color needs to be corrected. The yellows are greenish and I need more pink/red.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 51 Answers
Double check you vga connectors and make sure they are plugged in all the way and screwed in snug also there might be a AUTO config button on you monitor you may look for that and press it if there is.
Posted on Jan 29, 2009
Greenish tint
Might try the color tones buttons on T.V. up or down.
Oct 13, 2013 | Samsung LN-S1951W 19 in. LCD Television
Yellow screen
There are a variety of problems that can happen to the display monitor of an Acer laptop.
The most common problem is the screen fading or becoming too hard to see.
This can be corrected by adjusting the brightness levels.
Another common problem involves incorrect color, which can be resolved by adjusting the display color settings.
Yet another big problem is the display freezing or appearing jumpy, which can be resolved by updating the display driver.
Hold down the "Fn" key.
Tap the right-arrow key to brighten the display screen.
Tap the left-arrow key to darken the display screen.
Release the "Fn" key to save your display settings.
Color
Right-click on the desktop and click "Graphic Properties."
Adjust the screen resolution by clicking "Display Settings" and choosing a resolution setting from the drop-down menu.
Click "Apply" to check the resolution of the display.
Click "OK" to save the resolution settings.
Adjust the color of the screen by clicking "Color Correction" and moving the brightness or contrast slider to the right or left.
Click "Apply" to check the color resolution of the display.
Click "OK" to save the color settings.
Click "OK" to exit the Graphic Properties application.
Update the Display Driver
Right-click on the desktop. Click "Personalize," "Display Settings" and "Advanced Settings."
Click the "Intel Graphics" tab and choose "Monitor Properties."
Click "Driver."
Click "Update Driver" and choose "Search Automatically."
Click "Install" to install the updated monitor driver. After the driver has been installed, click "OK" to restart the laptop when prompted.
Yellow screen
Yellow tinting in monitors can be caused by either a software calibration issue, bad cables or a worn out display and backlight.
Before you assume that the issue is a hardware one, determine if there are software settings that affect the color or if the cables are working correctly.
After checking these items, and if the yellow tint only occurs on one monitor and you cannot eliminate it, the problem is a display hardware issue and it is less expensive to replace the monitor.
Unplug the power cord from the monitor and replace it with another one.
This is a standard power cord used in printers, monitors and desktop PCs so you can trade it for a cable from another device.
Turn on the PC and monitor to see if the yellow is still there.
Turn off the computer and monitor.
Replace the video cable with another VGA cable from another monitor.
Use one from another computer before going out to buy one.
Restart the computer to see if the yellow tint is gone.
Right click any area on the desktop and click "Properties" from the list of options that appears.
Choose "Display Settings," then "Advanced Settings."
Select "Monitor" and click the "Calibrate Color" button.
Wait to see if the yellow tint goes away.
Locate the temperature color settings on the monitor.
Adjust these to see if there is a change in the color.
A warm color setting will give the screen images more of a yellowish tint.
Click on the "Start" icon, then click "Control Panel" and "System and Security" and choose "Device Driver."
Locate the video driver and click "Update."
Select the option allowing Windows to connect to the Internet to find an updated driver.
Wait for the update to complete in a few minutes.
Expect the yellowing issue to disappear.
Connect the PC to another monitor to see if the same problem occurs.
If the yellow tint does not appear on the newly connected monitor, the problem is a bad backlight or display and the monitor should be replaced with a new one.
http://www.adobe.com/education/pdf/cib/ps7_cib/ps7_cib17.pdf
Jul 21, 2013 | Acer Computers & Internet
Hello, My name is Diane. I've had my flat screen Acer monitor for 14 months and all of a sudden my monitor has no red, orange or pink color. My screen colors are green, blue and yellow. What is the...
hello Diane, actually yellow is mixed red and green.
I thing you should check your cbf cable first (VGA cable).
Or if you have pattern test, use it to make sure which color has lost.
Change VGA cable may can solve it.
If any problem, please let me know.
Thanks and good luck.
Mar 27, 2011 | Computers & Internet
My printer is Fuji xerox 1250, Recently i have a problem for the color issue, we tried color Calibration, We changed drum, we even reset to manufacturer default setting (by press 0+ green button and...
It seems your yellow color is not function correctly. Need to check yellow color feed and its linkage to deliver ink to your paper. Looks like it almost clog up that cause very light color in your paper. Again please check completely your color feeds.
Regards,
Dec 15, 2010 | Fuji Office Equipment & Supplies
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
The 3 colors wires that hook into my pc are yellow, red & blue, but the colors on the pc are: pink, white and blue is there a color match up?
I suspect you've got the audio and video cables mixed up.
Video inputs on monitor will be yellow for video and red/blue for audio. PC end of cable will be round and connect to your video card. Or .. you should have a cable with a 15 pin mini D on both ends or a DVB cable.
The pink, white and blue connectors on your pc are audio connections for speakers/headphones.
Google is your friend
The ... Google is your friend
Jul 07, 2009 | Acer AL1951Cs 17 inch LCD Monitor
The colors on my monitor are faded/bright always changing.
Right click on your desktop (not an icon but a blank space), click "personalize", click on the tab on the far right(settings), click the drop-down menu on the left side above the colored banner, make sure it is set to the most colors(usually 32). If you need a walkthrough for Vista I can provide that as well.
Jun 14, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Overall color change (greenish) 10 seconds at a time with multiple computers
It is due to dry soldering on the crt board. Try to resolder all the dry joints on the crt board.
May 23, 2009 | Gateway EV 910 19" CRT Monitor
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Monitor too bright
Your video card (or driver) is probably to blame.
Try hooking a new monitor up to the computer to test this.
If so, try the advanced settings in control panel. Many cards give you the ability to manually alter the picture.
If that doesn't fix it, replace the card.
Mar 14, 2008 | Acer AL1916W 19" LCD Monitor
Acer X193W LCD Monitor Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
