Question about LG VX5200 Cellular Phone
Front Display My front display turned black the other day. At first it started with the screen being black when i pressed one of the side buttons. Once i opened the phone and closed it the screen would return to normal. It did this multiple times and the time right before it turned permanently black the screne had rainbow swirls all over it. If anyone can help me that would be greatly appreciated. The screen still lights up but it remains black. Thanks in Advance ~Amanda
This seems to be a common problem. The same thing happened to me about 8 months ago. I'm still using the same phone, and I even have to carry around a list of contacts just so I can call people. I brought the phone into the Verizon store and they claimed it was water damage. The little water damage sticker thing didn't show that it was water damage, but they said there was corrosion inside the phone. I still don't believe that it was water damage, considering the number of people that had the same exact problem. I get to upgrade soon though, and I've learned my lesson - I'm getting the full coverage insurance. Just so they don't try to say it was water damage again, if anything happens, I'm just going to say it was stolen.
Posted on Sep 21, 2007
SOURCE:
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
...hi, i've got a 2" wide black vertical area on
That reads like an alignment problem on the monitor, rather than a computer setting.. If you have a flat-panel monitor, usually on the front, lower right or along the right side, you can press a Menu or Settings button, press + or - to the Horizontal setting, press the Select button, then press the + or - button to move the display to the right. Press the Select or Menu button again to set the new location.
The actual button designations could be different.. best if you look at the manual on the monitor.
If graphics card will let you oversize the display, it might also have a Pan option that would let you slide the display back to the right. In that case, look in the Notification area (lower right) of the screen for a graphics card icon that will let you Pan right.
Oct 30, 2013 | Computers & Internet
No remote to turn off display
Hello
If there is a "Menu" button, on the front panel of the TV, press it, surf through its menu options [display options], and turn OFF the dispay. If there is no Menu button at its front pane. you cant turn the on screen display option without a remote control.
Feb 27, 2012 | Protron PLTV-32 Television
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
May 29, 2008 | Canon PowerShot A710 IS Digital Camera
No dispaly
The 2 extra wires will most probably be temperature sensors.
If your using the onboard video, then make sure you have memory in the first DIMM slot (it will say DIMM1 beside it)
If that dosn't solve the problem then try these:
  • Remove the memory and reseat it. Make sure to put it back in the correct way. There is a notch towards one end that will match the notch of the memory slot. Press it in until the 2 clips lock fully, then give it a gentle wiggle side to side while pushing down still.
  • Listen to the beeps your computer makes when starting up. A single short beep is what you want to hear. If you hear. If you hear something else then post back what it does. There are long and short beeps that could be involved.
  • Disconnect all the IDE cables from the back of the drives. You can leave the power cables connected. When they go back in they also have a notch and can only go in one way.
Try those for a start and post any progress you make. Also just double check the video cable is correctly attached at both ends to the computer and to the monitor.
Apr 10, 2008 | ASUS P4S800-MX Motherboard
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
LG VX5200 Cellular Phone Logo
144 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
