Question about Kitchen Appliances - Others
Janitrol furnace wont ignite
I have a fairly new (10 yrs old) janitrol furnace which wont ignite it goes through all the motions trying to ignite but after about 2 to 3 minutes there is a hissing noise that try's to ignite then it shuts down. The light indicator blinks once according to the control panel is ignition failure. It says check gas flow or gas pressure orgas valve or flame sensor. How and in which order should I do these?
It is probably a bad hot surface ignitor
Posted on Feb 21, 2009
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
My janitrol furnace started to make a lot of noise over the last few days. Could something be loose or does it need to be cleaned?
I hate to say it but it sounds like the bearing in the fan is going out. If your lucky there's a replacement...if not then a new furnace. You will have to have it looked at by a furnace tech.
Its too bad I can't hear the noise then I'd have a better answer for you, sorry.
Dec 30, 2014 | Goodman 66005 Furnace Draft Inducer Motor...
Where should the flame blow when janitrol furnace is ignite?Toward firewall?
It sounds like he incorrectly installed the igniter and it may be a huge danger to your home. A incorrectly installed igniter can cause a excess build up of gas and blow back flame or worst blow up your house. Only have a licensed heating and cooling contractor work on your furnace and not a handy man.
Nov 22, 2014 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Have a rheem furnace/ten yrs old.just replaced thermocoupler and gas valve,furnace will turn on thermocoupler will get red but no heat? whats up?
I know it may sound strange but check to make sure the gas cut-off valve is turned parallel with the gas pipe. If its open, you may have a failed fan proof switch. air pressure from draft induced blower causes the switch to click and open the main gas valve. if this this switch doesn't click(close contacts) the maing as valve will not open to ignite the burners. its a sequence of events that a furnace goes through before it ignites the burner for heat.
Nov 28, 2010 | Heating & Cooling
Ignition problem with furnace
hi igniter could be in the wrong postion or its not heating up all the way down or its got a crack in it
Jan 22, 2010 | Heating & Cooling
Armstrong furnace ultra 80sx doesnt always lite on first try,service repair man replaced smartvalve,sensor and igniter he says its ok if it doesnt always lite on the first try ,sometimes it takes three...
Sounds like your gas valve is sticking. Your repair man is somewhat correct by meaning that the furnace will attempt to start 3 times before going out on "Lock-out". The furnace is reaching it's expected life and you will start experiencing more frequent issues with it. Check into some of the incentives to get a replacement with a higher efficiency rating. The newer units have greatly improved in performance as well as comfort.
Jan 13, 2010 | Heating & Cooling
Janitrol gup power vent ignition sequence
inducer motor should run for several seconds before furnace lights, this proves the pressure switch and ensures proper ventilation
Sep 30, 2009 | Goodman Heating & Cooling
16 year old Heil 75K btu furnace, some times does not ignite.
recommend getting a carbon monoxide indictor or having some one test it. with it being over 15 yrs old if checks good replace ignitor assy should fix it ok
Dec 14, 2008 | Cross Furnace Draft Inducer Blower 115...
Kitchen Appliances - Others Logo
596 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
