Question about Brother CS-80
Brother Innovis 4000 D stopped sewing
The post that makes the needle go up and down is stuck in the down position.  The hand wheel will not turn.  If I try to force anything the needle area shakes and give me a error safety message.
Just got the machine, what is going on.  I only used for straight utility stitch today, the needle broke - I took it out with tweezers as the needle got stuck in down position have not been able to use it since.
  • Anonymous Mar 16, 2014
    needle doesn't go down Like the wheel is sticking. Safety device activates
    material gets caught and has to be cut
    New Friend:
  • 186 Answers
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
Posted on Jan 30, 2009
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Sep 15, 2016 | Simplicity Sewing Machines
How to fix a hand wheel that doesn't move.
if its stuck physically then don't force it , have a look with a strong light in the bobbin compartment for foreign objects , ive seen needles break off and lodge in the bobbin spool locking it tight
Mar 10, 2016 | Euro-Pro Sewing Machines
Hand wheel wont turn to raise needle.
If handwheel does not turn, you may have thread jammed in the hook. First try to force the handwheel BACKWARDS to try to force thread back out of hook. If handwheel turns, look around hook area and you will probably see a small piece of thread. Remove it with tweezers. To help eliminate this from happening, be sure to hold the needle thread when starting off.
Jan 18, 2015 | Brother Computerized Sewing/Quilting...
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
Elna 6200 jammed on bobbin refill setting
Remove thread. Remove the needle plate. Turn hand wheel toward you. Rethread machine. Make sure presser foot in up position when you thread needle. Make sure needle all way up in shaft, flat side back and more rounded side facing you Turn hand wheel toward you again and observe the following: As needle comes down, make sure the needle's eye makes pass by the scarf of the needle. Hope this helps, and if not, try
Apr 03, 2012 | Sewing Machines
My Kenmore sewing machine model 385.15212 is stuck in the needle down position. I have cleared the threads and cleaned the bobbin area. Tried to force the hand wheel, but it won't go, and don't want to...
I doubt it is a motor problem but it is too jammed up to turn the motor-you are right not to force it. Take out all of the bobbin parts again and leave them out. Now unscrew the needle and while lowering it, into the needleplate hold it tightly and remove it. Clear all thread from the machine and it should now move freely.
Reassemble the bobbin parts and reinsert a new needle being careful to insert it fully and correctly.
Jun 11, 2009 | Kenmore 15212 Mechanical Sewing Machine
Brother CS-80 Logo
380 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
