Question about JVC DRMH20 DVD Recorder
Power surge has killed my DR-MH200SEK
We had a series of power surges and one of them managed to knock out my DR-MH200SEK, I checked the internal fuse, which had blown, so I replaced it, but as soon as I turned it on, it blew again. Any ideas what would be causing this and if it is a problem that I can resolve without costing me an arm and a leg, or do I need to resign myself to the fact that I will just have to but a new one?
    Scholar:
    New Friend:
  • 70 Answers
Gargame,
good day, if you already replaced the fuse and still keeps on blowing it again. you still have a short circuit somewhere within the power supply area or board.try to check if there are any other blown parts or slightly expanded shape part specially for capacitors near the power supply area .
2) If you do have multi tester and have some basic knowledge with component checking try to check the polyswitch protector, this is connected parralel to AC supply right after the fuse before going to voltage rectifier diode.
3) if it doesn't have a polyswitch protector check the polarity of your rectifier diode, maybe 1 of this 4bridged diode is shorted.
cheers,
mark
Posted on Jan 30, 2009
I have a Dell computer that will not come on since a strong storm came through and knocked out the power into house! What needs to be done to get it up and running again?
Power supplies have an internal trip feature. Unplug the power supply from the wall power. If the power supply has a switch on it, cycle this switch as well. Wait about one minute and try again. Also, ensure that the surge suppressor/power strip/wall outlet has power. Also, disconnect and LAN and modem cables that are attached to the unit. A power surge thru one of them can cause damage to the mainboard that would affect the ability to power up. If the unit still will not power up, chances are that the power supply or mainboard has been damaged.
Aug 01, 2014 | Computers & Internet
Fuse replacement
No fuse or rest switch. Usually a power surge will destroy the tv's circuit boards. Check wall plug or power bar to make sure the breaker did not pop.
Jul 20, 2014 | ON Technology RCA LED40C45RQ 40" 1080p...
Wont turn on but tries too come on,power light blinkink
Internal power supply failure. Was there a lightning storm in your area recently or utility work being done recently? This two things usually kill TV's and other electronics with surges when power is restored. If the set is under warranty call the manufacture, if not, call you homeowners insurance agent to see if the damage is covered w/or w.o. deductible. At least you can get something toward repair/replacement costs. Future fix, purchase and install a surge arrestor in your main AC panel for the whole house or buy a power strip with a built in surge filter/protector for your expensive equipment.
Jan 23, 2014 | Samsung PN51D490 3D Plasma TV
Power surge knocked out power How do I get to the power source?
This problem can might involve in some internal circuit check up, if you are confident about your technical skills then download the service manual to check the power circuit thoroughly or else get it checked from some hardware shop.
Sep 30, 2013 | Brother HL-4150CDN Laser Printer with...
MALIBU 200 WATT IRON CORE TRANSFORMER MODEL NO 8100-0200-01 LIGHTS WONT TURN OFF
Plug power pack into cheap wall timer, and that will operate lights until warranty is resolved with Malibu or product-seller.
Simple power outage, or nearby lightning strike, can cause surge that will knock out digital timers. And knock out analog series power packs too.
You probably need receipt for warranty claim.
This timer is not shown on Intermatic site, and not subject to Intermatic 5-year warranty, but certainly Malibu must have a warranty of unknown length, and a corresponding claim procedure.
Double-check your installation, and additional resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Whole-house surge protection is hot item among folks these days since so many household items are now electronic, including appliances, washer-dryer, water heaters, timers, etc.
This will protect both 120Volt and 240Volt circuits, although it is unknown if your timer failed because of surge..
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Sep 29, 2012 | Hardware & Accessories
I had a power surge about a month ago and now my wii will not turn on. My wii is pluged into a surge protector.
I posted this elsewhere on here too, but I'll post it here too so it helps you.
This is a common problem with the Wii. You wouldn't believe how often I read about this. I'm very surpised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Monitor just went off. no power light. changed fuse but monitor is completely dead
possibly a power surge killed the main board in the LCD. if the fuse was blown i would suspect a power surge. you could replace the circuit board. either that died or the power supply died- depending on if it has internal or external power supply that might be blown as well.
i would take it to a professional LCD/ LAPTOP repair person. they should be-able to test it and let you know what needs to be replaced
Aug 06, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
JVC TV AV-32260 power surge now power button flashing
Check for swollen top on power supply capacitor ......check
all caps with ESR meter....all with C900 series location #'s..
also check C523 in horiz drive circuit..............T.
Dec 01, 2007 | JVC AV-32260 32" TV
Power surge - how to repair??
Power surges on these can take out the main board (unnumbered), modem(3), and power supply(4), approx 150 each.
Jan 26, 2007 | Brother MFC 8820D All-In-One Laser Printer
JVC DRMH20 DVD Recorder Logo
353 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
